Best method to clean your speakers
thsmith
thsmith Posts: 6,082
edited March 2009 in Vintage Speakers
What technics are people using to clean their speakers and the face that holds the speakers? Not that mine need it but I am curious.
The 6 1/2s look like they have a sticky surface, if they were dusty how would you clean them.
What is safe to use on the MW and woofer surrounds ?
I have seen some of the vintage posters before and after pics and they look amazing.
Thanks for your feedback.
  • Mike Kozak
    Mike Kozak Posts: 931
    edited November 2008
    I have seen posts there that say to use windix I think...for the drivers anyway
  • BigMac
    BigMac Posts: 849
    Lasareath wrote: »
    Windex, spray 8 or 9 squirts on a piece of paper towel per each 6.5"
    you can see I did the same on my web album below.
    http://38.161.195.8/Polk-SRS-2's/html/IMG_0019.htm
    I second that, windex works great for my woofers on my 10b speakers. I also read in a few threads on other forums that some people were applying Armour All to make their speakers look better, that is a BIG NO-NO.
  • TNRabbit
    TNRabbit Posts: 2,168
    I've never used anything besides a damp towel/washcloth. Repeated use of Windex or other harsh chemicals can lead to discoloration. Just ask the guy on eBay who sold a Sunfire amplifier that had turned *PINK* from repeated use of Windex....
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
  • zingo
    zingo Posts: 11,258
    I would just do the damp towel unless the windex is needed. No harm can come from a little damp towel treatment.
  • thsmith
    Great ideas and feedback, THANK YOU ALL !
    I assume it would also be good to use something like a new paintbrush to remove any dust and dirt before putting a damp towel to them.
  • michaeljhsda2
    michaeljhsda2 Posts: 2,207
    "The 6 1/2s look like they have a sticky surface, if they were dusty how would you clean them."
    Should one avoid touching the paper towel to the sticky surface? It seems to me that the paper towel would stick to the surface and not come off.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • nadams
    nadams Posts: 5,877
    The sticky surface is normal on vintage polk. It's a coating that they used to deaden the cone. clean the surrounds, but I wouldn't go after the cones themselves. I know just how annoying it is for them to be sticky, what with 3 cats in the house... That's why I leave the grills on all the time.
    Ludicrous gibs!
  • michaeljhsda2
    "I wouldn't go after the cones themselves"
    Thanks for the confirmation!
    Mike
    SDA SRS 2.3TL's
    SDA 2B TL's
    F1nut Posts: 52,382
    It's perfectly safe to clean the Polk MWxxx cones/surrounds with Windex. In fact, I highly recommend it, just don't do it every week. Do NOT use paper towels, rather use a soft cotton cloth. Never spray the Windex on the cones, spray it on the cloth and wipe in a circular motion.
    Never clean/dust any finished wood item with Windex as the ammonia will soften the finish and if left wet long enough, will eat thru the finish. A damp, soft cotton cloth is best.
  • HB27
    HB27 Posts: 1,518
    Windex works fine. I've been using it for years. Don't spray the woofer just the paper towel. I use Bounty paper towels dampened. The Bounty doesn't leave fibers when dampened. Careful of some of the generic "Windex" products. Lots of ammonia and it WILL soften the adhesive holding the rubber surrounds to the frame.
    I bought some M-10s from a bar that were covered with smoke and used too much cleaner and the surrounds did peel up on the edges. They glued back down in place but left the surround "edgy".
    Harry
  • michaeljhsda2
    Thanks for the info Las, F1, HB. I'll be cleaning the cones for the first time in 22 years.
    Mike
    SDA SRS 2.3TL's
    SDA 2B TL's
  • tx_polkhead
    tx_polkhead Posts: 248
    Each of the sets of speakers (3) that I've found on CL needed a little TLC. One set I 'rescued' from a college kid was so dirty and covered with cat hair that I think I could hear a difference after the clean up! I used windex that I further diluted with a little water and Q-tips, lots and lots of Q-Tips!
    Polk Audio RTA 12c's, Monitor 7c, Monitor 5JR+, SDA CRS+
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited March 2009
    +1 on the Windex.
    I'd read advice for using it several times and ended up using it to clean the drivers on my 7A's about a month ago. I used some Bounty paper towels and didn't have any issues with them...just sprayed about 6-7 squirts of Windex onto a folded paper towel for each driver. I was amazed at how much gunk and grime got pulled off of the cones. I bought the speakers used a few months ago and from the looks of them, I don't think they'd ever really been cleaned before. It made them look a million times better.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • BIZILL
    BIZILL Posts: 5,432
    edited March 2009
    okay, what are you all using for the wood???
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    7.1 SURROUNDS: RTI6'S
    XBOX 360
    WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
    http://polkarmy.com/forums/index.php
    bobman1235 wrote:
    I have no facts to back that up, but I never let facts get in the way of my arguments.
  • gdb
    gdb Posts: 6,012
    edited March 2009
    BIZILL wrote: »
    Which finish ?? Paste wax for polyurethaned panels and tung oil for walnut veneer. Safety tip: If you use tung oil...do not....leave rags around because they will spontaneously combust and burn your house to the ground !!:eek:
  • Mike Kozak
    edited March 2009
    I cleaned mine with Murphys Oil soap and water (wood)
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited March 2009
    Armour-All Baby!!!!
    What's it been now, 4 years? Trey is never going to live that one down :D
  • sakina4
    sakina4 Posts: 2
    I learned a lot from reading everyone's posts, thank you, It's better to clean old speakers with a slightly damp cloth than with chemicals. My phone's speaker was cracking, but after using the water eject feature on the Fix My Speaker website, it got better. I can share the link if you want. Thank you so much.
    audioluvr Posts: 6,065
    sakina4 wrote: »
    No that's okay. You know what works even better? Putting your phone in the dishwasher!
  • sakina4
    sakina4 Posts: 2
    audioluvr wrote: »
    sakina4 wrote: »
    The joke was definitely enjoyable. But seriously, some sound-based cleaning techniques, like the one I used can be really effective at removing small amounts of water if it gets in. Of course, proper maintenance and care for any appliance is always a good idea. Thank you sir.
    F1nut Posts: 52,382
    ^AI fail^
    F1nut Posts: 52,382
    ^Please flush the AI troll^
    pitdogg2 Posts: 27,884
    A mental one at that!
    Viking64 Posts: 7,805
    There's AI.
    Then there's WOKE AI. :o
    Go away!
    Get out of here
