Lumin D1 plus Sbooster Power Supply combo
txcoastal1
txcoastal1 Posts: 13,513
edited May 2025 in For Sale (FS) Classifieds
So I purchased this from a Polk member a couple years ago and actually never open the box :D:D . Had a project that I never finished. D1 Sbooster Combo's are going for around $900....Sbooster botw p&p eco 12v-13.2v
So let's say $625 plus actual shipping.
Ships in original boxes plus double boxed together.
Sale is for Polkies only with a minimum of 25 posts till May 25th 2025.
That does not mean I will sell to just anyone after the 25th, seller (ME) discretion will be enforced due to fraud/scammers.
  • Malbec
    Malbec Posts: 558
    edited May 2025
    Hey Ron, Is the Lumin silver or black?
  • DaveHo
    DaveHo Posts: 3,583
    Tough to make out 100%, but I believe the white tag says Silver.
    treitz3 Posts: 20,017
    It does.
    It is silver
    VR3 Posts: 29,448
    Definitely silver
    Giving this a bump
  • newbie308
    newbie308 Posts: 803
    I have zero experience with Lumin products, so can you tell me if this streamer is compatible with android devices and can it play Qobuz? Also, would this be a significant upgrade to a Bluesound Node?
  • CottageChz
    CottageChz Posts: 416
    newbie308 wrote: »
    I have a D1, it does have Qobuz. Here is a link to the android app, not sure how much you can do without having a LUMIN device on your network, but check it out:
    https://play.google.com/store/apps/details?id=com.luminmusic.lumincontroller
    I cannot comment on Bluesound vs LUMIN, have never heard the former.
    According to Qobuz, all Lumin products should be able to stream via Qobuz or Qobuz connect, and yes. They are Android compatible.
    I have had the BS Node2 and I have a Lumin player, but it is at another level than the one listed here, so I can't comment on the sound difference. That may just boil down to the DAC used in the device and how good the PS is at thwarting noise from entering the unit.
    VR3 Posts: 29,448
    I had the u1 mini which is similar and honestly once you go to the s booster it compares favorably to their higher tier products.
    I could discern no difference between the u1 mini with s booster and the u1 and u1x
  • PSOVLSK
    PSOVLSK Posts: 5,390
    edited May 2025
    I’ll take it Ron.
    Edit to say, I’ll take it if newbie308 hasn’t already got it.
  • PSOVLSK
    I may have spoken too soon. Looks like the Lumin might require an Ethernet connection. Can anyone confirm this?
  • CottageChz
    PSOVLSK wrote: »
    Accurate. Probably some kind of adapter you can get to work around this, but it does not have built in WiFi.
  • PSOVLSK
    CottageChz wrote: »
    PSOVLSK wrote: »
    Thank you.
    Looks like I can run an Ethernet cable from my mesh to the Lumin…but my music room isn’t really the best place for my mesh.
    Hmmmm. What to do?
    @newbie308, why don’t you buy this and make my decision for me.😀
  • newbie308
    PM sent
    newbie308 wrote: »
    PM sent
    Replied sir
    SOLD SOLD SOLD!!
    Thanks Dan
