Lumin D1 plus Sbooster Power Supply combo
txcoastal1
So I purchased this from a Polk member a couple years ago and actually never open the box
. Had a project that I never finished. D1 Sbooster Combo's are going for around $900....Sbooster botw p&p eco 12v-13.2v
So let's say $625 plus actual shipping.
Ships in original boxes plus double boxed together.
Sale is for Polkies only with a minimum of 25 posts till May 25th 2025.
That does not mean I will sell to just anyone after the 25th, seller (ME) discretion will be enforced due to fraud/scammers.
Hey Ron, Is the Lumin silver or black?
Tough to make out 100%, but I believe the white tag says Silver.
It does.
It is silver2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Definitely silver- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Giving this a bump2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
I have zero experience with Lumin products, so can you tell me if this streamer is compatible with android devices and can it play Qobuz? Also, would this be a significant upgrade to a Bluesound Node?Enjoying the journey while never attaining the destination.
I have a D1, it does have Qobuz. Here is a link to the android app, not sure how much you can do without having a LUMIN device on your network, but check it out:
https://play.google.com/store/apps/details?id=com.luminmusic.lumincontroller
I cannot comment on Bluesound vs LUMIN, have never heard the former.
According to Qobuz, all Lumin products should be able to stream via Qobuz or Qobuz connect, and yes. They are Android compatible.
I have had the BS Node2 and I have a Lumin player, but it is at another level than the one listed here, so I can't comment on the sound difference. That may just boil down to the DAC used in the device and how good the PS is at thwarting noise from entering the unit.
I had the u1 mini which is similar and honestly once you go to the s booster it compares favorably to their higher tier products.
I could discern no difference between the u1 mini with s booster and the u1 and u1x- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I’ll take it Ron.
Edit to say, I’ll take it if newbie308 hasn’t already got it.Things work out best for those who make the best of the way things work out.-John Wooden -
I may have spoken too soon. Looks like the Lumin might require an Ethernet connection. Can anyone confirm this?Things work out best for those who make the best of the way things work out.-John Wooden
Accurate. Probably some kind of adapter you can get to work around this, but it does not have built in WiFi. -
CottageChz wrote: »
Thank you.
Looks like I can run an Ethernet cable from my mesh to the Lumin…but my music room isn’t really the best place for my mesh.
Hmmmm. What to do?
@newbie308, why don’t you buy this and make my decision for me.😀Things work out best for those who make the best of the way things work out.-John Wooden -
SOLD SOLD SOLD!!
Thanks Dan2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
