What model are these speakers, please
Inherited them from my father. My mother was using them as plant stands! Looking to match a bluetooth amp.
Best Answer
Polk SDA 1A. They are 4 ohm loads, so you need a dedicated power amplifier rated to drive that load.
Do you have the SDA cable that connects the left and right speakers?
I know nothing about Bluetooth amps, nor do I care to.
Answers
If you connect them with the interconnect cable your amp will have to be a common ground amp.L600 (front), R200 (rear), R200 (rear surround), L400 (center), Sunfire HRS-10 (2)Marantz AV7706Sunfire Cinema Grand, Marantz M8077, Music Hall Stealth, Ortofon bronze cartridge, Parasound Zphono XRM, Sony UBP-X800
Could be interesting….
Thanks for all the info, folks. Alas, I don't have the SDA cable.
One tweeter and the dimensional driver will not work without it. So don't go thinking you've got blown drivers.
The blade/blade cable is still available on ebay, cost about $50-$60.
