MW 6501 or 6503?
benvee
Hello, I just got some 1985 SDA CRS speakers. One of them has a replacement driver installed, a MW6501. One has a frozen driver, an original 6503. I would try to recenter the magnet to get it working again, but I figure it still won't match the 6501. So the question is, should I
A try to find a used 6501 to replace the frozen 6503, so both of the SDA drivers will match,
B try to find a 6503 to replace the mis-matched driver and repair the frozen driver?
I've searched the forum here, and I understand the early CRS is not the most desirable model, but I'm willing to work with it for now.
Answers
MW6501
MW 6501 1.47 5.96 N 3.25 E - 3N/M 7.75 Ohms 31 Hertz
MW6503
MW 6503 1.82 5.24 N 3.55 E - 3N/M 6.54 Ohms 29 Hertz
Pretty sure they used the 6501 because it was the closest to 6503
https://www.ebay.com/sch/i.html?_nkw=polk+MW6503&_sacat=0&_from=R40&_trksid=p4432023.m570.l1313
Get some spares, they are getting harder to aquire. MW6501in good shape is as hard to find as hens teeth.
Thanks, I will do that. I figure I'll try to sell the MW6501 and buy the correct driver. -
How many 6503’s do you want?
Well if I try to fix the frozen 6503 I have, I only need one to replace the incorrect driver. If I'm lazy/ the price is right I will just get two 6503 and put off fixing the frozen driver. -
