Polk Audio SDA SRS 2 Crossover Modification Thread
    VR3 Posts: 29,756
    edited February 2013
    Getting there...
    VR3 Posts: 29,756
    Douglas Connection SDA cable!! :)
    VR3 Posts: 29,756
    ALL DONE! :)
    I am pretty proud of these bad boys!
    To give you an example of how awesome this all was, it had to go inside of THREE boxes ;)
  • Conradicles
    Conradicles Posts: 6,435
    Fantastic work VR3!!!
    VR3 Posts: 29,756
    Thank you sir!! :)
  • drumminman
    drumminman Posts: 3,396
    Very nice work Trey. Clean and neat - love the p to p wiring. Looks like a cost no object Xover rebuild - $400 in resistors alone! :eek:
    VR3 Posts: 29,756
    Thanks man!!
    The resistors were not to bad, only $2.50 a piece
    VR3 Posts: 29,756
    He is getting them installed! :)
  • zarrdoss
    zarrdoss Posts: 2,562
    That is some damn nice work! some of the nicest I have seen, These do use a 130uf cap on the low end right?
    VR3 Posts: 29,756
    Thank you sir! :)
    It is actually closer to 190uf I believe, they are beside the big inductor!
  • zarrdoss
    Well a 130, 65 and two 34's right? A 130uf must be the size of a coke can!
    VR3 Posts: 29,756
    I just used two 100uf since the 130 and 65 are in Parallel since they are the same values
  • zarrdoss
    I just looked at the schematic I wonder why Polk used a 65 and 130 wired in parallel? cost effectiveness probably?
    VR3 Posts: 29,756
    On the stock one, the 130 is poly cap I believe with 20% tolerance... definitely strange
  • PolkieMan
    PolkieMan Posts: 2,446
    Clean and neat truly professional looking!:smile:
  • Mr. Bubbles
    Mr. Bubbles Posts: 736
    Very very nice work. looks awesome.
    One thing i couldn't see in my mind. How thick was the plexi and the threaded rod? The reason i ask is i am trying to see in my mind how solid this is and/ or how prone to vibration it may be from the sound.
    Again; looks great, congrats to the owner.
    VR3 Posts: 29,756
    Thanks man!
    The "plexiglass" is not exactly "plexiglass" it is a material designed for circuit boards and that is very very dense. It is basically the thickness of a super nice circuit board. After all of the components were loaded there are nothing more than a thud! :)
    The itself definitely does not rattle... :)
    Thanks!
  • MAD
    MAD Posts: 105
    edited September 2013
    Looks beautiful, top notch professional job. I would definitely be tempted to leave the crossovers outside the box to show them off... but that's a lot of wire to deal with.
    any updates on how the 198 tweeters sound or did you go back to the 194.
    VR3 Posts: 29,756
    Thank you sir!
    As a professional policy as well as personal I have decided to not do any non-Polk approved modifications anymore...
    With that said, I believe the owner is happy with the overall sound of these! :)
  • zingo
    zingo Posts: 11,258
    Looks great!
    VR3 Posts: 29,756
    edited October 2013
    Thanks Jake! :)
    VR3 Posts: 29,756
    12 years later!
  • BlueBirdMusic
    BlueBirdMusic Posts: 3,137
    You are a true "ARTIST"!
    Harry / Marietta GA
