Polk CSI40 w/ Polk Monitor 7
I have an opportunity to purchase a CSI40 for a pretty reasonable price and was wondering if it’d be a good match with my old Monitor 7s?
  • jammosher
    jammosher Posts: 13
    Before someone suggests the 400i or the 350LS, I simply do not have the space to accommodate those speakers. I’m looking for the next best thing at a reasonable size.
    VR3 Posts: 29,752
    I don't have the dimensions on hand but they are actually very different
  • jammosher
    jammosher Posts: 13
    My mistake! I was under the impression that they were smaller than the 400i. Really, it’s the depth that doesn’t quite work with my tv stand. Any recommendations that are on the smaller side? Thinking of throwing in the towel and buying a CS245
    VR3 Posts: 29,752
    22-5/8"W x 7-1/2"H x 12-3/8"D csi40
    Shorter and wider
    Cs400i
    VR3 Posts: 29,752
    4 inches is alot for some 👀😂🙏
  • Conradicles
    Conradicles Posts: 6,433
    Does the cs300 fit?
  • jammosher
    jammosher Posts: 13
    I think the CS300 fits! I was looking into the CS-245 because it’s apparently a newer version of the 300, but I could be mistaken
  • jammosher
    jammosher Posts: 13
    I also have a CSi3 laying around, but I think I could do better…
  • Conradicles
    I had the CS300 years ago because it was the only one that would fit at that time. Good solid center channel speaker. I'll keep a lookout.
    VR3 Posts: 29,752
    Have you considered the old Polk rm series if depth is a concern
  • jammosher
    jammosher Posts: 13
    I’m reconsidering the CSI40; I definitively think I can make it work with my space, which begs the question again: is it a close enough match to the monitor 7?
