What can i do to fix this problem?
mitrawellnes
Answers
If your Polk MagniFi Max SR stops outputting sound after a while, start by power cycling the soundbar, subwoofer, and surrounds. Unplug everything for a minute, then plug them back in to reset.
Make sure the unit isn’t overheating. If it’s in a tight space or has poor airflow, it can cause the audio to cut out. Give it room to breathe
