You’re doing it wrong…
17576788081116
    pitdogg2 Posts: 27,236
    Have you used it for rust removal or cleaning something else?
    I've have not used it for rust removal. I bought a gallon of it last year on closeout for $8. I had planned on using it this year to clean hummingbird feeders instead of dish soap.
  • BlueBirdMusic
    BlueBirdMusic Posts: 2,807
    Doing it wrong on the water involving a boat 27 times
    https://www.facebook.com/reel/1375953493433885
    Sample: Man loosing control of his boat in harbor.
    Note: Having been around water and boats for many years when younger, I have seen similar things and experienced a few crazy occurrences. Mine: Total knockdown under sail with spinnaker in heavy weather on 30 foot boat. Hobie Cat turtle down with tip of 26' mast stuck in mud as I was trying to approach busy marina boat ramp in swirling winds. Anyone else?
    Harry / Marietta GA
    treitz3 Posts: 20,083
    There is a FB page I subscribe too, that has a plethora of examples like those. "Boat Fails of the Week" is the name of the group. Man, some people really should not be allowed to boat......or even put a boat in water!
  • CGTIII
    CGTIII Posts: 1,245
    edited April 2025
    Anyone else?
    Numerous sailboard adventures including losing sailboard on Lake Lanier, GA in winds of 20 gusting 35+, swells of 2-4 feet. Had to swim 30 minutes to shore in heavy wetsuit and walk two hours back to car. Retrieved gear the next day with a boating friend.
    Boston - CR7, CR6s, CR4s.
    ​Thompson Adventures, Inc.
  • BlueBirdMusic
    An OLD "Doing it Wrong" but Published 15:42 13 Apr 2025!
    NASA hired Lockheed Martin to construct the NOAA N-Prime weather satellite back in 2003
    Technician made simple error on NASA satellite that ended up costing $135,000,000.
    The accident occurred when the satellite was being moved from a vertical to horizontal position and accidentally fell a meter onto a concrete surface.
    An investigation into the matter was carried out after the costly mistake and revealed it was a very minor thing that caused the catastrophic damage.
    It was reported at the time that the physical damage caused was a result of the satellite missing just 24 bolts.
    The bolts were needed to secure the spacecraft to a device called the Turn-Over Cart (TOC).
    A report from NASA stated: "The bolts were removed from the TOC by another project while the cart was in a common staging area, an activity which was not communicated to the NOAA project team."
    https://www.unilad.com/technology/nasa/nasa-satellite-bolts-mistake-lockheed-martin-068918-20250408
    Harry / Marietta GA
    mhardy6647 Posts: 35,200
    "just 24 bolts?!?"
    I mean, someone at Boeing musta seen that and said "here, hold my beer". :(
    Four. Four bolts!
  • CGTIII
    CGTIII Posts: 1,245
  • CGTIII
    CGTIII Posts: 1,245
    VR3 Posts: 29,537
    Never understood exterior doors with glass larger than the average person.
    F1nut Posts: 51,952
    That is a typical English house. Why they like glass doors is beyond me.
    VR3 Posts: 29,537
    edited April 2025
    The new trend around me are garage doors with large windows on each panel where two full grown adults can fit thru...
    Does not compute!
    F1nut Posts: 51,952
    Should have added...the reason for the peephole is you can get those doors with frosted glass installed or you if you buy a house with a clear glass door already installed you can apply clear or tinted frosted vinyl to the glass.
  • daddyjt
    daddyjt Posts: 3,128
    ― Aleksandr Solzhenitsyn
  • daddyjt
  • CGTIII
    CGTIII Posts: 1,245
    nooshinjohn Posts: 25,985
    CGTIII wrote: »
    Must be why they call him Papa John...
    VR3 Posts: 29,537
  • OleBoot
    OleBoot Posts: 3,135
    Someone's doing something wrong here....
    Ron Wagner, former pilot in the US Air Force (USAF) 89th Airlift Wing (the “Presidential Wing”), recalls the best pilot-ATC argument ever on Quora;
    ‘My old time aviation buddies can skip this because it’s an old mythical story. Probably didn’t happen, but if it did, this was the best pilot-controller argument of all time!
    ‘Allegedly the German air controllers at Frankfurt Airport are renowned as a short-tempered lot. German controllers are tough and run airports like, well, like Germans were known to run things. No sense of humor. No room for error. And they were quick with tongue lashings for anyone who didn’t obey perfectly and quickly. They, it is alleged, not only expect one to know one’s gate parking location, but how to get there without any assistance from them.
    ‘A British Airways Boeing 747 call sign Speedbird 206 (the call sign for British Airways jets is Speedbird) landed and was handed over to ground control and given taxi instructions.
    Speedbird 206: “Frankfurt, Speedbird 206 clear of active runway.”
    Ground: “Speedbird 206 taxi to gate Alpha One-Seven.”
    ‘The BA 747 pulled onto the main taxiway and slowed to a stop.
    Ground: “Speedbird, do you not know where you are going?”
    Speedbird 206: “Stand by, Ground, I’m looking up our gate location now.”
    Ground (with quite arrogant impatience): “Speedbird 206, have you not been to Frankfurt before?”
    Speedbird 206 (coolly): “Yes, twice in 1944, but it was dark … and I didn’t land.”
  • skrol
    skrol Posts: 3,460
    How many beers?
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • BlueBirdMusic
    Harry / Marietta GA
  • CGTIII
    CGTIII Posts: 1,245
  • CGTIII
    CGTIII Posts: 1,245
  • CGTIII
    CGTIII Posts: 1,245
    edited April 2025
    Place I ate last evening was playing only 80s music. Hall & Oates is stuck in my head. :-(
    I've tried to have them change to Deep Tracks or Classic Vinyl.
    Say it isn’t so, cause I can’t go for that, no can do….
  • Geoff4rfc
    Geoff4rfc Posts: 2,933
    One on one I wanna play that game toni i ight
    Set up: 11.2 HT + 2ch
  • CGTIII
    CGTIII Posts: 1,245
    edited April 2025
    txcoastal1 Posts: 13,519
    CGTIII wrote: »
    When I am doing testing on mics at the stores and I have my speaker tester at the headend, I place my iphone at the mic and play stuff like this....even if you don't know the words, the tunes stick in your head.
    Employees and managers crack up, and later tell me they can't get the tunes out of their heads.
    https://youtu.be/S_Jzl_bx3fI
    https://youtu.be/wvUQcnfwUUM
  • CGTIII
    CGTIII Posts: 1,245
