Classic integrateds
I've been using classic integration amps in my system for a while now.
I really enjoy working on them. They are a lot easier to deal with than a
lot of newer gear.
1st up, the Marantz 1150 at 75wpc. I had an 1150d when I was on Okinawa.
I stumbled on this one for $100 about 12 years ago. It had a missing balance
Slider. I jumpers it out and then recapped it. Sounded OK, but not as good as
I remembered. Did a power amp board rebuild, much better. After about 2 years
I found a balance slider. Then a couple years later, buzzzz. That pesky duel ps
cap blew. Fixed that and rebuilt the power supply added 5 way posts and it
sounds pretty good. Note- all classic unrestored Marantz gear sounds like poo.
I got the Kenwood ka7100 in filthy condition. But it worked. Cleaned it up, did a
recommended rebuild of caps and known troublesome components. Added
Binding posts. Waiting 9 years for a set of reasonably priced knobs that weren't
all scratched up.
Cheated on my favorite, the Sansui au717. Got a good deal on a clean unit
That someone else rebuilt. Sounds great. Just added the binding posts.
It sound like a good quality modern integrated.
The one mistake was selling my au-999 that I rebuilt. It was a beautiful unit
that came with the rare wood case. I was moving and thinned out a bunch of
stuff.
Yeah, I know. No Pioneer. I'll find one somewhere.
    mhardy6647 Posts: 34,903
    The AU-717 was/is a fine amplifier then and now. Really nicely built, too.
    Oh, and beautiful to boot.
  • PSOVLSK
    PSOVLSK Posts: 5,371
    Always wanted to get a classic integrated even if only in a secondary system. One of these days maybe.
  • la2vegas
    la2vegas Posts: 762
    I've had/have a few classic integrated amplifiers over the years. Sansui AU517 that was so so. Later I picked up a near mint 717 that has come and gone. A Yamaha CA2010, also gone.
    Currently I have a Kenwood KA7300 with the matching KT7300 tuner. My latest acquisition is an AU919. Although it works flawlessly, sooner rather than later it's going to need some TLC.
  • motorstereo
    motorstereo Posts: 2,317
    edited April 7
    I've had a few vintage integrateds come and go here. Sui 9500 and 11,000, Kenny ka907, 9100 and 7300. Pioneer sa9500, a couple of Luxmans I can't remember the models and a Rotel 1412. My favorite of those was easily the Kenwood ka9100. All of them were brought home for under $200 with most under $100. Sadly those days have passed never to return.
  • jdjohn
    jdjohn Posts: 3,315
    I've got an AU-999 from my dad's collection, currently sitting in storage. Cosmetically, the cover is a little rough. I bought a refurb kit for it, which I need to get done. One odd thing about those is that the volume knob is small, or rather, the same size as all the other knobs :/
  • sucks2beme
    sucks2beme Posts: 5,680
    Go look at the rebuild threads at audiokarma. There are some good
    mods for the au999. The rated output as an integrated is about 20 watts
    Lower than the amplifier output when used separately. There's a preamp
    board mod that gives the full output. There are mods for better bass as
    well. The modular design makes it one of the easiest units to service.
  • skipshot12
    skipshot12 Posts: 1,772
    I’d give up my two 700 amps for a Krell FBI Integrated in a second.
  • jdjohn
    jdjohn Posts: 3,315
    sucks2beme wrote: »
    Thanks for the tip, and yes, that modular design is one reason I am willing to tackle a rebuild.
    I also have a 9090 (not a 'db'), and a kit for that, but it might not be as user-friendly; and, of course, it's not really an integrated ;)
  • sucks2beme
    I like that Sansui series. I bought a 8080 in 1977 on clearance.
    Great looking receivers. Definitely not as easy to work on as the
    Au999. That amp is a breeze compared to most to work on.
    Putting in modern binding posts makes it much easier to connect
    up modern speakers with quality cables. I believe I cheated a bit
    and used flush mount banana jacks. They fit in cleanly without
    having to hack things up. Ebay may have some custom solutions
    For this now like the 3d printed au717 speaker connections.
  • blademan13
    blademan13 Posts: 8
    Vintage integrated amps are my soft spot. I find the styling of the early to mid-70’s models hit my sweet spot. I just love the machined knobs and overall aesthetics of these units. I also find them very easy to listen to. I have a Sansui AU-888, Pioneer SA-8100, Kenwood KA-5002 & KA-6004 in various systems. They are even better when paired with a matching tuner!
  • la2vegas
    la2vegas Posts: 762
    A Kenwood KA-7300 and the matching KT-7300 that I have as my garage setup.
  • Conradicles
    Conradicles Posts: 6,323
    I keep a vintage rig set up at all times.
    Currently rocking this:
    Kenwood KA-701 Classic Integrated
    Kenwood KA-815 Tuna
    Tandberg TL 5010 Speakers
    Seriously considering sending the speakers to Trey for another crossover upgrade.
    tonyb Posts: 33,065
    sucks2beme wrote: »
    Where are you located ?
  • sucks2beme
    Near Memphis.
  • sucks2beme
    The Sansui drives a set of Sennheiser hd650's pretty well. Not quite
    as well as my dedicated tube headphone amp. If I'd never heard the
    Senn on tubes, I would be happy with the Sansui.
    SCompRacer Posts: 9,077
    edited April 16
    I got my Yamaha CA-800 with CT-800 AM/FM receiver combo back from Aaron a few months ago for my basement bench system. It's seen quite a bit of use. I only had room for a pair of Mission MS-50 bookshelf speakers, which sound pretty good. A Mitsubishi LT-5V vertical table was a perfect fit for the shelf.
    Yeah, a little messy... I have an antenna in the attic for FM.
    edited April 17
    The CA-800 is a redoubtable little amplifier. I love mine.
    EDIT: The CT-800 was/is also a well-documented sweet spot in Yamaha's long and rather distinguished line of tuners, too. :)
  • blademan13
    blademan13 Posts: 8
    I really enjoy my vintage integrated amps, particularly when paired with a tuner. Here is one of my office sets; m8mohdunj08g.jpeg
    Kenwood was/is first and foremost a radio company -- they made some mighty nice tuners over the years.
  • skipshot12
    My Dad had a Kenwood HAM radio. It was something to see.
    I’d sit for a couple hours drooling over that radio while listening to my Pop using skip to talk to folks on the other side of the world.
    Brings to mind some fond old memories.
    There's an old Lafayette Radio Electronics general coverage receiver upstairs that I am pretty darned sure was Kenwood (TRIO)-produced.
    source: https://www.worldradiohistory.com/Archive-Catalogs/Lafayette-Catalogs/Lafayette-1966-660.pdf
    But I digress. :#
    Yeah, inconceivable, right? :blush:
    Ahem.Kenwood (TRIO) did indeed (also) make some very fine hifi audio products -- and, AFAIK, Accuphase (founded by ex-Kenwoodians) still does. :)
