Polk SDA/SRS (first version) and Rogue Monos
I know these questions can become redundant after a while but want to ensure I don’t damage either my new amps or Polks. Does anyone have any experience with using SDA speakers with the Rogue M180 Tube Mono Block amps? Not sure if they are ‘common grounded or not or if they would cause damage hooking them up to my original Polk SDA/SRS speakers. I happened to come across a pretty mint set of the Polks which sound great but just changed my amps from a stereo SS amp to the Rogues. Would connecting some speaker cable between the two negative terminals of the amps resolve any potential issues? Thanks in advance for any advice.
    pitdogg2 Posts: 27,334
    Call Rogue and ask. They are great folks and answer questions quickly.
    I will state that the Rogue super magnum 99 preamp did not play well with my 2.3tl's because of the inverted signal. No matter how I hooked it up it created a very wonky sound stage.
    nooshinjohn Posts: 26,002
    Mono block amplifiers by their nature are not common ground. You need a robust stereo amplifier that is common ground in order to run the original SRS properly.
  • skipshot12
    skipshot12 Posts: 2,092
    Which version sda srs do you have?
