Polk SDA/SRS (first version) and Rogue Monos
Texas42
I know these questions can become redundant after a while but want to ensure I don’t damage either my new amps or Polks. Does anyone have any experience with using SDA speakers with the Rogue M180 Tube Mono Block amps? Not sure if they are ‘common grounded or not or if they would cause damage hooking them up to my original Polk SDA/SRS speakers. I happened to come across a pretty mint set of the Polks which sound great but just changed my amps from a stereo SS amp to the Rogues. Would connecting some speaker cable between the two negative terminals of the amps resolve any potential issues? Thanks in advance for any advice.
Mono block amplifiers by their nature are not common ground. You need a robust stereo amplifier that is common ground in order to run the original SRS properly.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Which version sda srs do you have?
