Odyssey Audio Kismet power amp in Khartago case
Odyssey Audio Kismet power amp in the smaller Khartago case.
This unit is not pictured on the Odyssey Audio website. It will have specs similar to this:
https://odysseyaudio.com/kismet-reference-amplifiers/
but look closer to this:
https://odysseyaudio.com/khartago-stereo-amplifier/
The Kismet is the higher line of amps and sports all the upgrades.
The Kismet version has all WBT connections, all Gronberg wiring and the SL series of capacitors. This unit has 4x 15k SL caps (2 per channel) mounted on the motherboard and 4x 16k SL caps (2 per channel) mounted off board. That's about 60k per channel. The SL series caps comes from the Symphonic Line series of amps out of Germany that Klaus also sells.
Normally this would have blue LED's to illuminate the Odyssey window but this one lacks those LED's installed. Klaus did provide them and I'll send them with but I won't install. You'll need to contact Klaus to get those in and if you're handy with a soldering iron it's not difficult. I'm not doing it as I know this works 100% and don't want to muck around inside the case.
I'll also remove the customized name plate on the back. There is a personal message in that from Klaus to me.
Faceplate is Very good to Excellent. You can see some of the imperfections in the case in the pictures
I've been using this for the last year or so but have gotten both my Kismet mono-blocks up and running so I have no use for this now. Purchase date on this is within the last 2 years. I believe I wandered out to the parking lot with it at the 2023 AXPONA.
$1200 and we'll work on shipping/insurance depending on where you are located. Local pickup is welcome. Payment via Paypal friends and family.
Will be double boxed (24x24x12, approx 45 lbs) shipping from Rockford IL.
Aaron
Enabler Extraordinaire
  • smglbrth
    smglbrth Posts: 1,504
    Nice..., GLWTS
    VR3 Posts: 29,751
    Great amp and price
  • indyhawg
    indyhawg Posts: 1,683
    Great price.
    Tony M Posts: 12,017
    B)
  • ALL212
    ALL212 Posts: 1,686
    I'll split shipping with you.
    If you're interested let me know as Klaus and I are to start some trading again and this might go away sooner than expected.
    Aaron
    SCompRacer Posts: 9,399
    ALL212 wrote: »
    ........ Klaus and I are to start some trading again.....
    I knew it! :D
  • ALL212
    ALL212 Posts: 1,686
    Last bump:
    If you’re at all interested let me know.
    Aaron
  • ALL212
    ALL212 Posts: 1,686
    Resurrection:
    Make a reasonable offer and we’ll discuss.
    Aaron
  • bnguyen866
    bnguyen866 Posts: 1
    Hi, is this still available? If yes I'd love to make an offer
  • whatusay
    Msg if available...would have to ship(would've liked to drive and visit family in Rockford)...but not possible
  • ALL212
    ALL212 Posts: 1,686
    No longer available
    Aaron
