Polks SDA 2B TL mod
  • keck
    keck Posts: 39
    anonymouse wrote: »
    Do NOT try to round out the edge. The particleboard is very weak and you will most likely end up with a mess. If you use H Nuts, ensure that you use the penetrating epoxy on the edges first and let it dry properly before you attempt the h nuts remount. Apply the epoxy to both the rim on which the basket sits, as well as the edge that goes into the speaker. I used moretite caulk to replace the gaskets. Use moretite only if you use the penetrating sealant as if you dont, the particleboard will break off sticking to the moretite. As I said earlier, go with cheaper binding posts as long as they are decent quality and aesthetically pleasing... again Dayton makes a decent product. Definitely not Cardas quality - but you are not going to discern any audible difference here.
    Sorry..... I post before reading your comment.. Thanks for the info.
  • rebelsoul
    rebelsoul Posts: 802
    Hopefully someone with experience will chime in, which is not me. I'm wondering what people think of the Erse Pulse X Polypropylene caps here: http://www.erseaudio.com/Products/PulseX
    I used them for my Monitor 10s and was very happy with them.
  • keck
    keck Posts: 39
    By the way, i can still order RD0-198 from Polks? Do they still carry them, or i will need to order from other site?
  • K_M
    K_M Posts: 1,631
    edited January 2020
    boston1450 wrote: »
    K_M wrote: »
    I don't get the impression that Dayton's are all that well thought of by folks here. Your list shows you going with Clarity caps for the low pass though so I'm confused......
    Have used them before, and outside this forum, they are well thought of.
    DIY forums view this stuff FAR differently by the way.
    Do you feel alone ? Lmao. I thought I post useless post & I do. But read this a few times & all I can do is scratch my head
    I am not even sure what you are replying to......??
    I said I had used Dayton caps and outside this forum (in reference to what someone else said) Dayton caps are well regarded.
    What do you not understand??
    I am scratching my head about why you even replied TO THAT comment
  • boston1450
    boston1450 Posts: 7,759
    keck wrote: »
    Try calling Polk Audio. They may still carry them. Discounts being a member. Someone here has the # . Looking forward to your impression when your project is over. Great speakers to upgrade
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • motorhead43026
    motorhead43026 Posts: 4,128
    edited January 2020
    Midwest Speaker......Polk RD0198.
    And the boots you lick will stomp you too.
  • keck
    keck Posts: 39
    2 x 0.22 Ohm Vishay Mills MRA-12
    That should be 2 x 0.5 ohm.
    Hi F1, there is no 0.5ohm for Vishay Mills 12watts, I only see 0.5omhs for Vishay Mills 5watts. Does it work for 5 watts?
    F1nut Posts: 52,406
    The original resistors are 5 watt rated, so yes that one will work. Otherwise you could use this one, http://www.soniccraft.com/product_info.php/047-ohm-mills-mra-12-p-690
  • keck
    keck Posts: 39
    Hi all, i have been enjoying my SDA 2B with 194 tweeter replaced a few years back. Am now doing TL upgrade with Gimpod board.
    One board completed as below. Am i doing correctly. Need advise as i could not find any sample photo of the completed SDA 2BTL mod with Gimpod board anywhere online.
    Thank you
    VR3 Posts: 29,756
    edited March 2025
    I can't be of any help but I am almost certain you are missing some jumpers
    VR3 Posts: 29,756
    edited March 2025
    See below
    E to h, j5, j2, j1
    You can also remove j1 and go to a 5 pin and introduce bi wire connections
  • keck
    keck Posts: 39
    Thanks a lot VR3. This picture helps a lot. Always good to verify if unsure. 😊
  • keck
    keck Posts: 39
    Done up the mod and fully installed. Fire up with no issue. As expected, sound awesome.
    Once again, thank you all for the advise and sharing for the TL mod.
    F1nut Posts: 52,406
    Tony (Gimpod) did everyone a huge favor making those boards. Sure do miss him.
  • drop1
    drop1 Posts: 92
    I missed out. Those are amazing.
  • VSAT88
    VSAT88 Posts: 1,390
    keck wrote: »
    I don't see Clarity PX in 20uf or 40 uf here: http://www.claritycap.co.uk/products/px.php
    I found them in PartsConnextion
    anonymouse wrote: »
    I have been happy with Dayton on the low side. I have not done a set with Sonicaps on the low side though.
    Great to hear that. I was initially plan to use Dayton, but after reading the threads, some were saying to go for Clarity PX which is just a little more price differences 😀
    Hel-hockey stick use oil filled for the 40uF and 20uF and save a heap o dough for your tweeter caps. Almost no ESR, very high voltage, and last forever and a lifetime. They were good enough for Paul. My 2b's sound absolutely fantastic with any amplifier. Probably my favorite speaker.
