Polk tweeter retrofit guide (RT7)
Kelso1
Kelso1 Posts: 13
edited March 2025 in Vintage Speakers
I recently found the need for replacement due to failed adhesive on the original SL6501 drivers. Most of the people on this forum give positive reviews on the Dayton Audio ND-25FN-4 Neo driver. At about $10 each, these seem like a great budget option. I have included a walkthrough of the modification and installation for anyone using these on the RT7 or similar.
The parts/tools that I used ar as follows:
Extreme Power adhesive (quality super glue)
Precision glue tip(s)
Hobby knife
Small flat bladed screwdriver
120 grit sandpaper
Bottle of compound (or whatever you have that has a flat surface that fits inside your faceplate)
The replacement of both units totaled about an hour to complete.
Post edited by Kelso1 on
