Polk tweeter retrofit guide (RT7)
Kelso1
I recently found the need for replacement due to failed adhesive on the original SL6501 drivers. Most of the people on this forum give positive reviews on the Dayton Audio ND-25FN-4 Neo driver. At about $10 each, these seem like a great budget option. I have included a walkthrough of the modification and installation for anyone using these on the RT7 or similar.
The parts/tools that I used ar as follows:
Extreme Power adhesive (quality super glue)
Precision glue tip(s)
Hobby knife
Small flat bladed screwdriver
120 grit sandpaper
Bottle of compound (or whatever you have that has a flat surface that fits inside your faceplate)
The replacement of both units totaled about an hour to complete.
Hobby knife
120 grit sandpaper
If your mount plate has seperated like mine did, a small flat blade screwdriver works well. -
A twist on the magnet and the assembly will remove, exposing the diaphragm.
The diaphragm tears away easily exposing the adhesive. Remove this as best as possible. It will clog the sandpaper if you do not. -
Using a hobby knife, remove as much of the ring as possible. This will make your sanding time considerably less. -
I used a bottle of joint compound that fit well inside of the faceplate. Whatever you use, place it on your sandpaper, trace a circle using the lid as a template, cut it out, and glue it to the lid. Easy and quick! -
After about 5 minutes of twisting and circular motions while holding the faceplate, we have a nice smooth, even surface.
The removal of the original tweeter exposed this o-ring. You can buy a new one if you'd like, but I decided to reuse it and overlook the small deformation. -
The reason this o-ring is needed is that the diaphrahm surround on the Dayton tweeter will contact the faceplate if a spacer of some sort is not used. It also acts as a seal to prevend unwanted noises.
It is almost a perfect fit on the tweeter. I used the glue with the precision tip to adhere the o-ring to the flanges of the tweeter (stretching where needed) -
Once the adhesive on the o-ring to the tweeter has set, place the assembly on the faceplate, align it, and run a bead of adhesive around the o-ring / faceplate.
After about 10min. cure time, you're good to go!
I hope this helps anyone considering the task. Good luck!
-Kelso
Nice work.
For future reference, I believe the SL6501 is interchangeable with the Polk SL5501, of which I have a large quantity. -
Here's the SL5501, which is a 6 ohm tweeter. What is the SL6501?
From my limited research, 6ohm.
Ok, then the info I saw was correct, they are interchangeable.
