How to Repair your Polk PSW505 Subwoofer
I hate to throw things away and I have been repairing amplifiers for almost 20 years so I thought I would find the problems with this sub and why most of them fail.
First thing the class D amplifier design is very simple and should work fine for this application and power level, so I dug into the circuit and tested every component. But every time the components were fine when removed from the board. But in the circuit they were still shorted. To keep this short the glue that was used becomes conductive after it gets hot shorting components. (this is very common on a lot of plate amplifiers made in china) It also appears to be corrosive and while looking at the board through a microscope I noticed that all the SMD components solder joints were corroded. So I scraped all the glue off the board (very carefully) using a dental pick and isopropyl alcohol.
Then covered the board in flux and tinned all the connections on the amplifiers SMD components. When I was done I cleaned the board with alcohol and tested the shorts. They were gone! I repeated this process on 3 different amplifiers and it fixed all of them. You will also need to replace all the small 22uf etc capacitors on the amplifier board at minimum. In my experience the large 3300uf caps don't fail very often. Obviously the best option is to replace all the caps.
I know these subs are hated do to all the failures, but if you want to put in some elbow grease they are savable.
I should probably add that if the board shorted it's possible other components can fail but most of the time the 9eu4h5fq5kgm.jpg
    Tony M Posts: 11,676
    I wish I had your skills!
    Great diagnosis on a ton of amp failures!
    Thanks for solving the issue of many of these failures that shouldn’t have happened in the first place!
  • dxrad
    dxrad Posts: 4
    I wish you would do a detailed step-by-step You Tube video on this fix!! Or better yet, start a repair business where we disgruntled Polk customers could mail you our plate amps for a definitive, lasting repair!
    F1nut Posts: 51,893
    edited March 2025
    dxrad wrote: »
    He gave you a written step by step.
    Judging by his username and verbage in his post I think it is safe to say he has an electronics repair business.
  • RichSNJ
    RichSNJ Posts: 3
    So I also recently discovered that my PSW505 was kaput. There was no power LED at all, and I had 15 volts on the 57 positive and nothing on the 57 negative. I started with the p/s and checked several of the 22 caps and they were really off, so I went ahead and replaced them all and got the correct 57 plus and minus Still no power LED though, so I went ahead and checked the caps on the amp board and they were also way off, so I replaced all 5 there as well, and success - red light green light and the subwoofer is back online... The board is a bit of pain to desolder on because all the white goo was blocking my desoldering gun and the through holes were too deep for braid, but I managed to do it. I can't believe how much a new subwoofer is these days, let alone the plate amp to fix this one...
