Hello all from Jakarta
Hello all...
i used to have polk sda crs complete with connecting cable between them.. use it for couple of years and then i sold it out... now i just get this speaker, it on the way to my home.. seems the model is monitor 5b ?
hope it can be as good as my old speaker... right now i just realize that its getting harder to get a good condition vintage speaker..
any advice for this speaker ? rebuilt the crossover ? or replace the tweeter ? i got it for 110bucks... seems for get the tweeter for this speaker gonna cost me more than the speaker itself...j5kc13a6iy0l.jpg
    treitz3 Posts: 20,353
    Hello and welcome to Club Polk....from the other side of the big, blue marble.
    F1nut Posts: 52,381
    That is the Monitor 5 Series 2 with the SL2500 tweeter. If you desire to replace the tweeters you want the RD0(zero)198-1, but the SL2500 is decent. Of course, upgrading the crossover components is a good idea.
  • dgozalie
    glad to know that the tweeter is not so bad... i will pair it with sony ta-5650 vfet amp... 50watt... hope the amp will have enough power to drive this speaker... anyway, happy to get this speaker in decent condition in jakarta...
    for crossover, i still looking for some information about it...need to do some reading and research in the forum...
    thank you for the warm welcome in the forum....
    msg Posts: 10,640
    Welcome!
    F1nut Posts: 52,381
    edited February 2025
    dgozalie wrote: »
    You shouldn't have any problem driving those speakers with the Sony integrated amp.
    Best to remove a crossover and look at the components for the values, which will be printed on them.
    F1nut Posts: 52,381
    This is the crossover. Unfortunately, the values are not visible.
  • Hermitism
    Hermitism Posts: 4,348
  • dgozalie
    The speaker arrive and it sound so good...the box condition also good, no crack or damage... polk must be using a hard/high quality wood not some cheapass MDF board...
    so i decided to upgrade the crossover... anybody got the schematic especially for this Monitor 5b gen 2?
    thanks in advance...
    F1nut Posts: 52,381
    The cabinets are MDF with either vinyl or veneer exterior.
    There is no schematic for those, which is why I told you to remove one crossover to determine the component values.
  • dgozalie
    okay, will do it asap...
  • dgozalie
    dgozalie Posts: 9
    Reporting that the speaker sound like ****... after i chat with the seller, the seller suggest me to do burn-in because the speaker haven't been play for maybe several years.. it is in the storage rooms and left there many years ago....barn find...
    well.. there goes 40 hours of stop and go music before i start a serious listening...
    F1nut Posts: 52,381
    Since I can't hear your speakers to know what might sound bad to you I will suggest it has nothing to do with them sitting around un-used. Rather, it is likely the electrolytic caps are way past their lifespan and need replacing.
  • skipshot12
    skipshot12 Posts: 2,142
    ^ Agree.
    Burn in has nothing to do with age. Age has a lot to do with degradation.
    Lots of people report breaking-in/burn-in can affect new gear, a rebuild or upgrade of parts as far as a change in sound over time.
    Does the speaker sounding like crap mean you did do some crossover work?
