Anyone has a schematic or service manual for any DSW-Micropro subs?
I recently purchased 2 of these 1000’s and both have now lost powering up. Both fuses have been popped. One sub for sure made a large hummm to a buzzzz and then a large snap sound. I pulled the amp plate off this one and found that the 660045-1 board has a blackened area around the lower centre and also around the H4 Cap series pair of the power supply portion.SeleniumFalcon wrote: »Sent..
Wondering I I could get any available schematics
Of this ? Thanks in advance.
Schematic sent..
I own two Polk DSW microPRO 3000. One of them went bad in 2018 and I sent it off to https://edwardselectronics.net/index.html to get repaired and it worked great. It's still alive today. The other died some time after and it's still dead. Looks like they removed the Polk amps from their repair list either lack of clients or they no longer can.
Good luck with your repairs.- Living Room Music-2.1 Polk Legend L800 | SVS SB1000Pro | McIntosh C70 | McIntosh MA5200 (Treble) | McIntosh MC452 (Bass) | Sublimeacoustic K231 Active xover | Denon DP-2500A | Denafrips Ares II | Marantz HD-CD1 | Belkin Soundform Connect | iPad Pro USB to DAC
- Home Theater-9.7.6/15.1 (Atmos/Auro-3D) Polk LSiM707, LSiM706c, LSiM702 F/X [x6], Height LSiM703 [x6], HSU ULS-15Mk2x4, VTF-15HMk2x2, VTF-TN1 | Trinnov Altitude 16+4 (2024) | Rotel RB-1590 (L/R) | Appollon NC500 11ch | Martin Logan MP500x2 | Topping DX7s, E50 | AppleTV 4K | Zidoo Z9X | JVC RS2100 | 150” Elite Screen Acoustic Pro UHD
- Game Room-5.1 Polk LSi25, LSiC, LSiF/X | Marantz SR7009 | AppleTV 4K | Sony UBP-X800 | Xbox One S | Sony PS2, PS3 | Nintendo Wii | Gaming PC | Sony 75" LCD
- Master Bedroom Music-2.0 Totem Hawk | Marantz PM-10 | Marantz SA-10 | SONY PS-HX500
- Office-2.1 B&W Formation Duo and Bass
- Daughter's Gaming Rig-2.0 Ascend Acoustics Sierra LX | Martin Logan Forte
- Orphans DSW microPRO3000x2 | Rotel RA-1570 | Marantz AV8805A
- Guest Room 2-2.0 Klipsch RP-600M | SMSL DO100 Pro 2 | Pass ACA v1.6 Monoblocks
- Guest Room 3-3.0 Martin Logan Motion 40, 50XT | Onkyo TX-SR705 | Apple TV | Samsung 55" TV
- Guest Room 4-2.0 QAcoustics 3030i | Sansui AU-6900 | Sansui FR-1080 | Fire TV
- Maintenance: Pro-Ject VC-S Record Cleaning Machine
Not really mentioned on their site, but do they only repair subwoofers?
I have a Sunfire TGA-7201 HT amp I need serviced
@SeleniumFalcon - Any chance I could get a copy of the schematics for the DSW-1000? Thanks in advance!
txcoastal1 wrote: »I own two Polk DSW microPRO 3000. One of them went bad in 2018 and I sent it off to https://edwardselectronics.net/index.html to get repaired and it worked great. It's still alive today. The other died some time after and it's still dead. Looks like they removed the Polk amps from their repair list either lack of clients or they no longer can.
These guys repair Sunfire subs.
https://www.ebcelectronics.com/?srsltid=AfmBOoqCilny2SM51eBrs_6Wopq7BDY16UmQUcmPaK1iSTw1lcly8BXRPolitical Correctness'.........defined
President of Club Polk -
Schematic sent...
Good day! My search for a schematic to repair a Polk DSW1000 has led me here. It seems it has been a while since there has been a post, but I am hoping someone might have the schematic and also notice my post!
Thanks in advice. -
Schematic sent...
Hi SeleniumFalcon, I see your message for 'Schematic Sent', but I can't seem to 'see it'. There is nothing in my messages or junk mail folder :-(
Any chance of a re-send and maybe how I can get it please?
Oh and so far I have found and replaced a bad 22mf 50v cap near the daughter board, (next to big caps), and found a bad sot-23 diode on the daughter board too. -
Re-sent...
Thank you for the schematic Selenium Falcon!
You're welcome, good luck with the repair!
So the schematic is described as DSW2/3/4000 and when I look at the component numbers on the PCB like Q4, U1, U2, R22, etc they do not correspond with the schematic which has larger numbers like D600. Are you sure the schematic sent should correspond with the DSW1000 sub?
Thanks again. -
I'll check with a source at Polk.
I'm afraid the current engineering department doesn't have any additional information concerning that series. In all likelihood the differences between the various models are some of the EQ parameters and the output stages. Most of the remaining circuitry would be the same throughout. Hopefully there's enough information to enable a repair.
Thank you SoleniumFalcon for checking, I will hopefully be able to take a closer look this week. What ever happens though I'll add a post about what I find.
@SeleniumFalcon I also have a DSW1000 in need of repair. Would you be able to send me a copy of the schematic?
Schematics sent...
Hello. I have a DSW3000 subwoofer. Power is not coming to the final amplifier. I would like to ask you for a shematic. Thanks in advance. -
Schematics sent...
Thank you.
You're welcome, good luck with the repair.
Hello - I also have a broken DSW micropro 1000.
Can you send me the schematic?
Thank you. -
Schematic sent.
@SeleniumFalcon I have DSW MicroPro 1000 that doesn't power up. Would you be able to share schematics? Thanks in ad.
Schematic sent.
Greetings, new to forum. My dsw2000 power supply fried. Need schematic for amp/ switching supply. Polk only had dsp board schematic. Thanks in advance.
Hello,
Welcome to the Polk forum. I'm afraid those are the only schematics provided by the vendor, sorry. -
Thank you
