MAGNIFI MAX AX ISSUE
Rutvik
Magnifi max AX soundbar is getting muted automatically and the white LED starts blinking. If I turn it off& then on again it starts but then again after 2 minutes, the same issue happens.
Hello,
I'll forward this to a contact at Polk and post his recommendations. -
He recommends:
"I first would recommend a power reset. Simply unplug the power to the bar for 5 minutes and plug it back in. Also, unplug the HDMI cable. Plug the HDMI cable back in once the bar powers back up." -
It’s likely an HDMI CEC issue with your TV. What is the TV model?
