SDA CRS+
Thanks for the help. My SDA CRS+ have the pin/blade design. Does the blade connection have a function or can I fashion a pin to pin cable and leave the blade connectors open?
    F1nut Posts: 52,406
    The blade is used for support unless you are using the AI-1 or Dreadnought isolation transformer then the blade carries a signal.
