SDA CRS+
JerzyDevil
Thanks for the help. My SDA CRS+ have the pin/blade design. Does the blade connection have a function or can I fashion a pin to pin cable and leave the blade connectors open?
The blade is used for support unless you are using the AI-1 or Dreadnought isolation transformer then the blade carries a signal.
