SDA CRS+
I just found a nice pair of SDA CRS+ speakers. They sound great. One question-do both 6 inch drivers play without the interconnect or does the second driver only play to use the phasing cancellation.
    Toolfan66 Posts: 18,290
    edited February 2025
    Listen to Ivan Below.. :D He is 100% correct.. B)
    pitdogg2 Posts: 27,557
    The SDA CRS+ should play both speakers from 120hz down because of the sub bass circuit. There was a big difference between the Blade/blade and the pin/blade models in the circuit they used. You would be best to use the SDA interconnect cord as it makes a huge difference.
    Ha, I wasn't thinking about B/B and P/B you are correct..
