SDA CRS+
JerzyDevil
I just found a nice pair of SDA CRS+ speakers. They sound great. One question-do both 6 inch drivers play without the interconnect or does the second driver only play to use the phasing cancellation.
The SDA CRS+ should play both speakers from 120hz down because of the sub bass circuit. There was a big difference between the Blade/blade and the pin/blade models in the circuit they used. You would be best to use the SDA interconnect cord as it makes a huge difference.
