Polk Monitor 7 Series 2 Audio quality question
Hi, I recently bought a set of Polk Monitor 7 series 2. The sound is generally excellent but the lower mid-range is kind of muddy. Cello, bari-sax, trombone, etc.
Highs and lows and upper mid-range are more crisp and clear. I’m thinking about
new caps or other upgrades. I’m asking
the Forum if this is just the way it is with
this model and very common- or if this is a sign of aging components and could benefit from a refresh? Thanks!
Answers
  • boston1450
    boston1450 Posts: 7,758
    @Basie1955 . Chances are being their age they are way overdue for a crossover refresh / upgrade. There may be a simple tweeter upgrade as well. There is lots of info listed here by search. Ask away & others will chime in. Welcome to the forum
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • Basie1955
    Basie1955 Posts: 10
    Thank you Boston1450. I did some searches
    and I read a lot about caps and resistors. I’m
    a non-technical musician who has an appreciation for good fidelity but little knowledge of how it’s produced in speakers.
    I appreciate your post. I thought someone may write that these are good speakers for the listener who can’t go full audiophile - but they do have a reputation for muddy / fuzzy low midrange. The shop I spoke with said they’re
    happy to do some work but it’s possible that
    that’s just a poor feature of this model. Big thanks for the welcome!
    F1nut Posts: 51,713
    The original Monitor 7 with upgraded components is an excellent speaker, no muddy anything. I've never heard the Series 2 version, but dare say the crossover components are seriously in need of upgrading as they are way past their lifespan.
    Do not use cheap components such as Dayton, Bennic or Solen caps.
  • Basie1955
    Basie1955 Posts: 10
    Thanks F1nut. If I have work done, what brand of caps should I ask for? I read Solen is OK but I’m more than happy to get your recommendation. Big thanks.
    F1nut Posts: 51,713
    Jantzen Superior Z, Sonicap Gen I or Clarity CSA are good choices. For resistors, Vishay-Mills.
  • Basie1955
    Basie1955 Posts: 10
    Big thanks
  • skrol
    skrol Posts: 3,438
    The Monitor 7 Series 2 (and some others in the Series 2 line) make use of a liminated core inductor in parallel with the tweeter. The engineer who voiced them told me the first thing to do is go air-core. It won't do anything for the bass but orher XO component refresh may help that.
    Also, make sure the cabinet is sealed. Gently press the PR in and hold. The MW should move out and stay for a few seconds. If not then you may have a leak, which would impact the bass.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • Basie1955
    Basie1955 Posts: 10
    edited January 22
    skrol wrote: »
    Thanks skrol,
    I’m mentally underwater with your post because I don’t have the technical knowledge.
    I have a vague concept of laminated core. Air-Core.
    I intended to talk with the repair guy and show
    him some forum comments. I’ll see what the costs are and if I can rationalize it.
    PR= passive radiator?
    MW= ? mid-range speaker
    Post edited by Basie1955 on
    F1nut Posts: 51,713
    Yes
    Vintage Polk mid-driver part numbers begin with MW followed by 4 numbers.
  • lmacmil
    lmacmil Posts: 122
    I just replaced the caps on one 1982 Monitor 7B. I did one so I could pan back and forth between the two. Frankly, my 76 year old ears could not hear any difference even though I'm sure there is one. Perhaps my 42 year old son can, I'll have him listen before I do the other one. I have tinnitus and I know I can't hear much beyond 8khz any more. That said, I'm not sorry I did it. It was literally a 10 minute job. I didn't un-solder the old ones, just clipped the leads, wrapped the new leads around the old and soldered.
    F1nut Posts: 51,713
    What caps and resistors did you use?
    pitdogg2 Posts: 26,980
    For the life of me I've never understood this method. It sure doesn't save time but now you have more solder joints and points of possible problems.
    F1nut Posts: 51,713
    ^THIS^
  • Basie1955
    Basie1955 Posts: 10
    Based on minimal experience, I’m having my Polk 7’s worked on by a pro shop. I realize it’ll
    be more expensive than DIY but they have the expertise. They will call me in a week or so with what they would recommend. It’ll be interesting to hear about the component’s current condition and what might improve the audio performance.
    F1nut Posts: 51,713
    Be curious to know what is recommended, so let us know.
  • Basie1955
    Basie1955 Posts: 10
    I’ll let you know. I suggested and they agreed
    at drop off that the 0198 tweeters would be
    a good idea. The guy said these M7’s sell for around $300 so I’ll want to be judicious
    about what they do and how much the upgrades
    will really pay off. I appreciated that because it told me they weren’t interested in sucking money out of my wallet for no reason.
    F1nut Posts: 51,713
    If you look at it that way don't bother doing anything with the speakers.
  • Basie1955
    Basie1955 Posts: 10
    So you don’t agree that some upgrades
    will be beneficial and some are not useful?
    F1nut Posts: 51,713
    edited February 1
    Basie1955 wrote: »
    If you are basing the cost of upgrades on what the market price of the speakers might be then don't bother upgrading them.
    Toolfan66 Posts: 18,014
    Basie1955 wrote: »
    You couldn't ask for an easier set of speakers to upgrade/work on yourself, and the rewards are well worth the extra using quality components..
    My advice, do them right, even if you don't do the work yourself, or just leave them alone..
  • Basie1955
    Basie1955 Posts: 10
    I appreciate your comments and I get what you’re saying. The tech was saying “Look,
    you’ve got a pair of speakers that are worth
    about $300 if you sold them. I’ll do whatever work you want done but you may want to
    weigh sinking hundreds of dollars into these.
    Maybe you just want better speakers”
    I really like these Polks. I also have M 4’s
    and M 5jr’s and Polk towers. I’ll wait to see what the tech says.
    My point was that I didn’t any see any logic
    in replacing every resistor, capacitor, coil, etc. if it wasn’t going to improve the quality of
    Stephane Grappelli’s violin. If the opinion comes back that replacing everything top to bottom will improve the audio quality, I’ll do it.
  • Gardenstater
    Gardenstater Posts: 4,771
    edited February 1
    He is probably feeling out where you are at and doesn't want an unsatisfied or irate customer 🤣
    How good is your hearing? Are you someone who has heard better audio quality by, say, changing cables? How much do you enjoy better sound?
    If you have heard and enjoyed better sound by changing cables ever before, I don't think any of the mods we talk about in this forum will not pay off for you, within reason. I would be hesitant to go with high end Dueland capacitors unless money is no object lol.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • Basie1955
    Basie1955 Posts: 10
    Yes, it’s good business to satisfy a customer with what they’ve been charged and the results they’ve produced. I do love great sound. My friend has Bowers and Wilkins that are astonishing but I don’t have 15k for speakers.
    I’ll let the forum know how it all came out.
    I listen pretty hard to music. I mean I concentrate on what I’m hearing. I’ve been a musician for years and I have opinions about how instruments and voices are ‘supposed’ to sound. Obviously it’s personal. Poor audio reproduction is a distraction from the music in that my attention is diverted from the music to
    the flaws in the speaker system.
  • lmacmil
    lmacmil Posts: 122
    The big one is Jantzen audio and the small one just said BP. I got them from Parts Express. I didn't do the resistors.
  • lmacmil
    lmacmil Posts: 122
    It certainly does save time. I'm not worried about the solder joints.
    I see no reason to put Duelands in a pair of Monitor 7’s. Sonicap, or Clarity will do just fine..
    lmacmil wrote: »
    I disagree, are you in some sort of race to get them done? You literally saved, what? 5 minutes of your time? Not like its hard to pull them off with a soldering iron..
    People like this, are people I don’t want working on anything I own..
    F1nut Posts: 51,713
    edited February 1
    lmacmil wrote: »
    So, you put a cheap electrolytic in for the tweeter, a higher quality film cap in for the shunt and didn't upgrade the resistors. No wonder you didn't hear a difference.
    If anything, the tweeter cap should have been a high quality film type and the shunt an electrolytic. High quality resistors also make a positive improvement.
