Polk Audio SDA SRS 2.3 Crossover Modification Thread
I was able to get Jantzen to build a C-Coil this time, oh yes. I am shipping Sean one with his next build to complete his Abbot modification.
I made it to where the tweeter negative takes up one Molex entry and the inductor connection is routed through the main connection so the wiring is very clean.
    VR3 Posts: 29,756
    Thank you :)
  • honestaquarian
    Yeah what he^^ said
    VR3 Posts: 29,756
    Thank you :)
  • ptrooper
    ptrooper Posts: 800
    edited October 2016
    Around 350 hrs and its like a switch has been turned on to the 2.3's every fine detail surrounded by an enveloping midrange and a bottom end that sinks into darkness....This is what its all about.Thankyou Trey...Can't wait for the SRS Abbots to the theatre rears!
    VR3 SDA SRS 1.2TL Duelund Monoliths+VR31000va Dreadnaught +VR3 MM2 SDA cable, <3 ,Lumin u2x ,<-sfp fibre <-LHYas8 Pro+ Switch,Transparent Reference MM2 xlr,power and speaker cables.FTA Sinope SE usb.40 Amp power line for amp with earth stake&Faraday shield ,20 Amp power line for digital equipment ->shunyata 8 venom power board...Working on it!
  • Hergy
    Hergy Posts: 3
    I have the older 2.3 non TL’s that I have lost my crossover upgrade schematic. Already have all of my sonic caps and the bigger circuit board.installed my rings re-sealed my cabinets, epoxied all of my magnets, dyno matted all of the cages. Have the black hole just needs to be installed. But I lost those damn instructions on changing over to the updated crossovers and caps! Can anybody help a brother out?
