Musical Fidelity Kw 550…
TroyD
TroyD Posts: 13,124
Is in the house!! One came up at a price I couldn’t pass up….and I’m as excited as a puppy with two peckers
That power supply is a BEAST. It’s gotta be 75lbs. I’m getting too old to schlep gear like that…..
Looking forward to getting in some listening!!
    VR3 Posts: 29,393
    Very very nice!
    Need more! Pics and a Polkfest!
    F1nut Posts: 51,686
    Nice Troy. Now you can make smoke come out of those ribbons.
    Clipdat Posts: 13,087
    That's a real big boy integrated right there! Congrats!
    Nice speakers, too! Enjoy.
  • Joey_V
    Joey_V Posts: 8,600
    One of the legends
    msg Posts: 10,452
    Excellent.
    pitdogg2 Posts: 26,950
    Congratulations Troy!!
  • WagnerRC
    WagnerRC Posts: 2,199
    congrats Troy. nice.
    billbillw Posts: 7,468
    That amp was on my short list before I went to the Class D dark side. I'm sure it sounds fabulous.
    treitz3 Posts: 19,950
    Trust me when I say that this amp will (properly matched) rock your damned socks off!!
    heiney9 Posts: 25,406
    Great score! Enjoy
    tonyb Posts: 33,067
    Nice....really nice Troy. Congrats on a nice scoop.
  • Jetmaker737
    Jetmaker737 Posts: 1,105
    Beautiful piece of gear! Enjoy.
  • TroyD
    TroyD Posts: 13,124
    So, I after a few hours of listening, I have a few thoughts but nothing that I'd hang my hat on other than this is a different animal from the Tri Vista or the A1008........
    I do have one quibble though.....for a company that has produced some amazing sounding products, of which I've owned a few, they all have the same crappy remote. It is BEYOND infuriating.
    Anyone have an aftermarket remote that they recommend?
    BDT
    VR3 Posts: 29,393
    My remote worked great with a ir repeater
    edited January 15
    TroyD wrote: »
    BDT
    Assuming you probably just need the simple controls like power toggle/input/volume control? I see that remote has a bunch of buttons for other MF devices, but I suspect you don't need those.
    Back when I had a BAT VK30, I used a URC-R7 which I found super cheap on eBay. It had a good ergo feel in the hand. Maybe check for that, or a similar R5, R6. The lower the number, the simpler they are. The question is whether they have codes for Musical Fidelity built in or not. You can usually find the list of manufacturer codes through a google search for the remote. Sometimes smaller manufacturers will use use generic codes from larger companies like Philips. That might take some research.
    Otherwise, Harmony remotes are great and they will certainly have MF in their code base, but they require software setup on a PC which some don't like.
    Remotecentral.com used to be a good source of info, but it seems like their website may be down permanently.
    EDIT: I was looking at some newer products from ONE for All. They have some newer universal remotes that use a smartphone app to setup. I cannot seem to find a list of manufacturers that are supported though. If you can find an older universal remote that has a "learning" function, you can probably get away with teaching the main commands from the MF remote. The inputs can be a problem though. You usually have to pick one of the number buttons and assign each, unless the MF remote cycles through each with a key press, then you can assign that to the channel up/down.
    Post edited by billbillw on
  • pearsall001
    pearsall001 Posts: 5,239
    Congrats!!! Dynamite integrated for sure. Many hours of audio bliss await.
    I feel your pain on the cheesy remote...it baffles me how companies can produce such great products then skimp on such a much needed remote. The remote should be on the same level.
    Nice score, Troy! Good on ya' bro'. Yeah, MF doesn't play around when it comes to those very heavy power supplies.
    F1nut Posts: 51,686
    billbillw, just fyi, the power button is manual on MF amps.
    Troy, I use an older Harmony 550, which I love. It has none of the MF remotes volume control issues. Harmony has stopped making remotes, but I believe they still support them.
    For a learning remote I can recommend a long out of production Sony RM-VL900, which you can sometimes find new on eBay.
    I knew they had a hard toggle power button, but I wasn't sure if there was a standby/sleep feature.
    Not on my amp. Hard button press only on both the PS and the amp itself.
  • Conradicles
    Conradicles Posts: 6,331
    I got an old Harmony remote if you need one Troy. Nice AMP!
  • TroyD
    TroyD Posts: 13,124
    Yeah, for an amp that goes for what a good used car goes for, I’m thinking a metal brick a la the Jolida JD100 remote.
    And the problem with ALL of them, they switch components perfectly…..volume control iis super frustrating
    F1nut Posts: 51,686
    Yeah, I don't get it. The Harmony or the Sony control the volume perfectly, so it's not the volume potentiometer, it's the damn remote.
    F1nut Posts: 51,686
    The newer remotes look much nicer.
    Speaking of that Jolida JD100....you ever get that thing back up and running?
  • skipshot12
    skipshot12 Posts: 1,823
    Congrats on that mamma jamma.
    Had the KW 500 pushing my Infinity Prelude MTS’ speakers and it was beautiful!
    msg Posts: 10,452
    +1 on their remotes. When I got the A5 running, that was definitely a wtf-disappointment after concluding it wasn't a singular fluke or narrow transmit angle. Too bad, too, because they've a nice look and feel to them.
    I learned my MF remotes into my URC MX-800 remote, but the learn capture wasn't accurate, despite a few tries, and sometimes my volume knob will "run away". @F1nut told me he experienced similar, and that a Harmony resolved that. They were already discontinued by that point and difficult to find on the 'Bay, or stupid expensive.
    If/when a runaway happens, you'll be proud of your panther-like speed and leap capabilities. But since you're not new to MF @TroyD , have you experienced this already with your prior MF gear?
    Best keep limber. Gotta wear wristbands, headband, and stretch out before listening sessions. Also recommend sippy cups for bigboy sodas to mitigate spills.
    Troy's able to leap small coffee tables in a single bounce once he gets the angle right off the small workout trampoline....correct. Okay maybe two bounces.....
    FYI: I see used Harmony 650/700 models quite frequently on Facebook Marketplace for under $50. Those two are basically the same except for color. If buying used, you can usually tell if they were seldom used by how much wear is on the volume/channel/d-pad buttons. I've seen a few that look practically new.
  • TroyD
    TroyD Posts: 13,124
    Appreciate the remote suggestions!
    So just in a couple days of listening….wow. This is a completely different animal than the tri vista or the A1008. Incrementally better in some respects….bass definition, for example. Lacks that glorious midrange liquidity of the tri vista and top end sparkle…but holy crap, solid, 3D, holographic imaging batman.
    Again, more to follow but this was unexpected for sure….
