What speaker For Surround Left e right?
Hi all,
I'm new for Forum and also for Polk.
In a 7.1 home theater system paired with a Marantz Cinema 40, I recently purchased a pair of R600s as front speakers, an R350 as the center speaker, and two R100s as rear surround speakers. My question now is what to choose as surround speakers for the left and right sides. They are aligned with the listening position. Due to space constraints, I need to stay within a depth of 15-17 cm max. Any ideas? I was considering the ES10s, but I'm not sure if they match the rest of the setup, or perhaps on-wall speakers from other brands. My budget is around €500-600 max. I also considered R350 in vertical position but it's out of budget and a little too deep.
Note: I live in Italy.
Note 2: White speakers are preferable
BEst Regards Luca
  • Geoff4rfc
    Geoff4rfc Posts: 2,817
    albaluce wrote: »
    Hi all,
    BEst Regards Luca
    Welcome to the forum Luca!! In my experience, the surrounds don't need to be timbre matched like the front stage should be. I'd recommend grabbing whatever you can afford and give them a try.
    Set up:
    Marantz AV8802A - Sources: BRP Panasonic 9000/CDP Emotiva ERC 3 - Display: LG OLED EVO 83 C3 - Amplification: Emotiva XPA-DR3, XPA-6, XPA-2 x 2 - Speakers: Focal/PolkAudio, Mains/2ch - Kanta No2, C - LSiM706, SS - LSiM702, WS - RTiA9, RS - RTiA9, FH - RTiA3 - Subs: Epik Empires x 2
    Cables: AQ McKenzie XLR's from CDP to AVP to amp for 2ch, Emotiva XLR's for the rest - Douglasconnection: Furutech Alpha 36 12g speaker wire for 2ch, Furez 10g speaker wire for the rest - AQ Forest48 HDMI for the display, AQ Carbon48 HDMI from BRP to AVP - VR3 filtered power cables for CDP, BRP and AVP, Emotiva power cables for the amps - AudioQuest 505 power conditioner.
  • albaluce
    albaluce Posts: 2
    I Share my decision with forum.
    Finally I got Polk Es10 (I found it on sale at very small price: 165€/pair) It's much better than B&W M1 (I tested it side by side) more natural on high freq and vocals. For a small size it's sound impressive.
  • sm1th5
    sm1th5 Posts: 18
    edited February 24
    You are doing yourself a disservice for the r350 center and the color white.
    I would automatically take the r100 or r200 for side surrounds as the first option always.
    Kef q4 meta would be my only other idea to look at.
    I don't touch anything with undersized woofers/drivers due to their lackluster sound quality.
