Help me evaluate this photo....decent enough or shoddy
heiney9
heiney9 Posts: 25,430
I am looking at purchasing a DIY Pass Camp Amp. He states he's an experienced builder and there are no issues with the amp.
I look at the solder job in this photo and to me it looks a little shoddy. I don't expect perfection, but those that do a lot of parts and wire soldering, what do you think?
Maybe use an image program to enlarge the red and black wires if you can't see what I'm talking about.
I can go in and fix some solder joints, but this makes me less confident that this will be a long running piece of gear.
P.s. He's supposed to be sending me more interior pics, we'll see if that happens
    VR3 Posts: 29,409
    I've seen better and I've seen worse, but definitely some questionable looking joints
    pitdogg2 Posts: 26,988
    Is that normal? Why wouldn't the solder mask be on the back side of the board?
    billbillw Posts: 7,498
    He definitely didn't own a resistor bending tool.
    VR3 Posts: 29,409
    Probably on both sides, I have seen several circuit boards where there's two tracks, one for the front and one for the back as well
    Viking64 Posts: 7,533
    billbillw wrote: »
    I would resist her if she tried bending my tool.
    For this DIY build I think so for the transistors and the minimal amount of wiring which are soldered to the front. The wiring is soldered after the pcb/transistors are affixed to the heat sink. The board is populated first, sans wiring. He was either lazy or fibbing a bit about his skills.
    The amp is cheap enough to probably take a chance on. I just want to see more of the insides before I buy it.
    The latest version of this DIY is sold out and the built ones FS are a bit pricey for me to take a chance on.
    There is a newer, more robust version called the ACA Minmax, but at $400 for the entire unbuilt kit, I'd like to see if it's even worth it for me.
    I had an original bought but at the last minute the guy said it started having issues and he refunded my $$$ before he shipped it. I'm glad he was honest, but I was a little disappointed.
    Just tinkering around with a low power, near field listening rig. The Schiit Gjallahorn so far hasn't really impressed me. Is it the amp or is it the pre/dac I'm using? Don't know for sure. Need another low powered amp to compare.
    Maybe I should pull out the Aleph 30 w/this pre/dac and see how it sounds?
    txcoastal1 Posts: 13,505
    @EndersShadow
    Dan, didn’t you win a drawing at LSAF for DIY Pass amp already built?
    audioluvr Posts: 5,896
    No no no! There's no enough twists on the red and black wires!
  • WilliamM2
    WilliamM2 Posts: 4,806
    The red/black wires definitely look like they are all cold solder joints. The solder didn't even wick up the strands, or fill the holes in the PCB.
    I rarely solder, and I can do much better than that.
  • jdjohn
    jdjohn Posts: 3,335
    I'm sure it's functional, but I would definitely touch-up those red and black wires if it were me.
    treitz3 Posts: 19,966
    Based upon what I see? I would inspect or redo every single solder joint within. I have literally seen rookies do better than what we see in the photo.
  • mrbigbluelight
    mrbigbluelight Posts: 9,878
    Long story short:
    That's some k-r-a-p soldering work.
    End of story. 🤔
    He hasn't sent other photo's of the interior. I decided to pass....no pun intended. His puffery didn't seem to match what I see visually. Or he's just lazy and doesn't care.
    EndersShadow Posts: 17,701
    txcoastal1 wrote: »
    @EndersShadow
    Nah it was that pair of wooden horns that I won.
