SDA 2A no bass in left speaker
acscience
Hey all,
I have a pair of SDA 2A speakers that were previously working great. After a move, now I’m not getting anything from the bass driver in the left speaker.
I’m not too speaker-savvy so after opening it up and not seeing any glaring issues like disconnected wires I’m pretty much at a loss. Any help would be super appreciated, I’m assuming I’d need a new driver?
I am using the distance cable also, not sure if that matters. Doesn’t change anything when I unplug it.
Here’s what it looks like behind the bass radiator:
Does the driver in question move freely?
BTW, it's called the SDA cable, not distance cable. What you called the bass radiator is called a passive radiator. -
Your crossover should be mounted. It appears as if it is completely free from any structure whatsoever.
Could you possibly add some additional photos from within the speaker itself, if it isn't too much trouble?
BTW, please allow me to offer you a very warm welcome to Club Polk.
One board XO, might be SDA 2b. SDA 2a was a two board XO.
I'm in the camp that a magnet has slipped as well. What are the driver numbers? MW6510, MW6511, MW6503?
Also was there any polyfil that was right behind the passive or is it still only behind the active drivers? -
Not sure what you're looking at, but it is mounted.
Thanks so much everyone for the help and the correction on terminology! The driver is mounted to the back, I took it off to take a better look but it’s been reattached in the picture. I will grab more pictures today and see if I can slightly move the driver in and out or see if it’s seized.
Also just to educate me a bit, what is the purpose of the SDA cable?
Thanks again, be back shortly. -
I didn’t see anything behind the passive at all. What would I be looking for? All I saw was some styrofoam inside the passive.
There should be no driver mounted on the back!
The SDA cable enables the SDA driver(s) to function. SDA speakers have stereo and SDA drivers.
All the polyfill should be above the PR, so you're good. -
My sda 2a crossover doesn't look like the one the OP has pictured, if I remember correctly there are 2 round circuit boards, one mounted to the binding post plate and one mounted to the big inductor. -
Does this mean that I have the 2B? I see a date of 1989 on the stickers found on the components.
If you would give us the midwoofer numbers we would be able to tell you.
Is the SDA cable pin/ blade or dual blades or is the SDA socket in the cup or outside the binding post cup on the back of the cabinet? -
I will get some more pictures posted today. SDA is pin/blade. Pin on top, single blade on bottom.
Those are SDA 2b studio models.
First thing I’d check is all the connectors to the board. Unplug and plug back in.
Would be a good time to check all connections. -
You can TL all single board crossover models
You can actually TL the sda 2a with the dual boards, but you can't use an isolation transformer.
skipshot12 wrote: »First thing I’d check is all the connectors to the board. Unplug and plug back in.
While he has or had the passive off, yes worth checking, but the first thing on his list is checking those drivers.
Oh yes, especially after a recent move.
