Cary --> Rogue or Primaluna?
acmf74
in Electronics
Hi folks...
I currently have a Cary SLP-03 preamp that I use for 2 channel and HT. I was looking to possibly pick up a different pre-amplifier in the Rogue or Primaluna line with a phono input.
Has anyone had any experience with the Rogue RP-1 or Prima Dialouge?
TIA
TIA
Mark Levinson No27.
Logical next step is SLP-05. But no phono.2 Channel Rosso Fiorentino Volterra II, 2 REL T9x, Norma Revo IPA-140B, Norma Revo DAC-2, Lumin U2 Mini, VPI Signature 21 w/Hana Umami Red, ModWright PH-150, SonoruS ATR10, AudioQuest Niagara 7000 w/Dragon power cable, WAY power cables for all other sources, WAY Silver 3 Ana+ speaker cables, WAY interconnect cables
AND, if you're running a sub, think 'bout this ...
There are only 2 outs; 1 XLR and 1 RCA. So 1 set to mains and 1 set to subAC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12 -
I would steer you towards the Cary 98 in the FM. Otherwise, given your choices, I'd rank them as Cary 98 or the 05, Primaluna, then Rogue.HT SYSTEM-
lsi 9's -
When PrimaLuna first came out, I darn near invested. I have always like their stuff, and they seem to have some longevity and established respect now.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
If you are happy with your present preamp, why not get a stand alone phono preamp?If you can't hear a difference, don't waste your money.
I had a primaluna amplifier for a very short time..then I sent it to Danny for awhile I when I picked it up at LSAF in Dallas I talk Dennis @dkfreebird into buying it so I wouldn't have to take it back home... I sure both will tell you how much they like it!2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
Why not look for a Levinson pre?The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
I have Rouge amp, downside tube sockets are on a PCB. That is not good. Primaluna is good stuff, I don't like auto bias. I am going in near future buy an Cary integrated amp. They will build with your choice of capacitors or power transformer for tubes they you may use. I must likely use 6550's tubes, use KT120 in my Rouge, not a big fan of this tubes.
Cary, FYI, has longevity and reliability issues.
My Prima Luna Evo 400 preamp is fantastic.
Great build quality and the sound in my system is outstanding.
