How to check for proper function L800
warlocks1
warlocks1 Posts: 1,284
I am picking up a set of L800 and want to verify they work properly.
Can I verify SDA effect if I connect the SDA interconnect cable to both speakers and then disconnect the amp connection connection to one speaker? Will the SDA speaker driver still play on the disconnected speaker? If so, then I can do the same with the other speaker?
Answers
    F1nut Posts: 52,406
    edited December 2024
    The way the SDA operates in the L800 is very different than the originals. Each L800 contains a stereo crossover and an SDA crossover, they are sort of mirror images of each other.
    That said, I have no idea what would happen if you disconnect one speaker.
    The L800 crossover, one side stereo and the other SDA.
  • warlocks1
    Too complicated for me
    Would it be safe to say if all the drivers are moving and sound out of both tweeters, they are probably good?
  • Emlyn
    Emlyn Posts: 4,905
    There is some guidance from Polk regarding checking for absolute phase, which seems to be related to SDA functioning and setup but requires a balance control. I must admit it's a little hard to follow, especially when it says the true center for an amplifier may change at different volume levels:
    https://www.polkaudio.com/on/demandware.static/-/Library-Sites-polk_northamerica_shared/default/dwb6ce935d/downloads/legend-series-setup-en.pdf
    VR3 Posts: 29,752
    There's a track on tidal called stereo left right, I use it to test sda functionality when I do my mods As it is a dude talking saying left right, nice and simple
  • warlocks1
    Great. Thanks Trey
  • boston1450
    boston1450 Posts: 7,759
    VR3 wrote: »
    I use this disc here just for that. I picked it up in a DVD/CD pkg deal years ago. It's a cd-disc cleaner w/brushes as well.YouTube may have it as well. l0ahf6agxfcb.jpg
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • warlocks1
    Sorry to be a pain on this, but it's a decent drive and I want to ensure they work properly so I don't have to bring them back.
    I have to bring my own equipment to test. I am bring an integrated amp with balance controls. If I turn the balance to left only, should I hear SDA speakers from the right speaker?
    I believe that works with the old SDA's
  • Emlyn
    Emlyn Posts: 4,905
    Yes. Can also test with a home theater receiver's speaker level test tones. The test tone for the right speaker will play in the upper portion of the inside array in the right speaker and the outside array of the left speaker. For the left speaker it's inside array for the left speaker and outside array for the right speaker. It's clearly audible in both speakers.
  • warlocks1
    Thx
    I would prefer not having to disconnect one of my receivers to do test tones, but will if the balance trick doesn’t work on the integrated.
    Sorry that I just sold my Marantz receiver. Replaced it with an Arcam
    I am picking up on Sunday
    thanks
  • warlocks1
    Thanks!!
    One you state the inboard drivers(non SDA) fade out do the outboard drivers (SDA) still produce sound?
  • warlocks1
    Perfect.
    Thanks everyone.
    Hopefully, pics to show this
    Weekend
