7A with unique cabinets
The original owner had the dealer put formica on them to match his decor at home better. 7v80z73zzjf2.jpeg
  • DeRod
    DeRod Posts: 249
    Those look nice! I was thinking of maybe doing wood veneer on my 7s. Did you just get those? I got a pair a few months ago and changed out the old capacitors. Very inexpensive and makes a huge difference.
    "Equality is a myth to protect the weak. Some of us are strong in the Force, others are not. Only a fool believes otherwise." - Sith Proverb.
  • motorstereo
    motorstereo Posts: 2,359
    Those are poor looking joints and with the sloppy caulking job on the tweeters it gets 2 thumbs down from me.
  • DeRod
    DeRod Posts: 249
    Thats probably not caulking behind the tweeter. Its probably mortite that they used on the very early ones. I just got a pair of minis and they had it on there just like those.
  • odcics2
    odcics2 Posts: 382
    That’s mortite. These haven’t been messed with.
    Perhaps the joints looked better when new?
    Anyway, I think they look cool and are certainly unique. I have the original boxes too.
    As a plus they are airtight and sound great.
  • DeRod
    DeRod Posts: 249
    I agree, sweet looking pair of 7s. Nothing screams 1970s like formica! I think they are awesome!
    pitdogg2 Posts: 27,188
    I'm sure it made the cabinets stiffer.
    I'm also pretty sure they had a wood veneer, walnut maybe 🤔
  • Gardenstater
    Gardenstater Posts: 4,790
    edited November 2024
    I'm pretty sure that no "dealer" was installing walnut formica on Monitor 7s :)
    Somewhere I have a brochure that showed that, for a time, they were available with real wood walnut veneer.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • odcics2
    odcics2 Posts: 382
    Just relaying what the old guy said...
    I'd think that the "dealer" would have sent it out to be reworked. The "dealer" certainly didn't do it in his back shop... Or did he?
    Maybe the dealer and original owner were buddies? Maybe it was a favor?
    I agree that the cabinets would be stiffer. That's always a good thing.
    The front edges are the original vinyl. Can't be seen when the grills are on.
    FYI - the back has no Formica.
  • Formica of the era definitely had a prominent inner substrate of dark brown phenolic, and the melamine finish layer was applied to that. Would be very obvious at the edges where one panel meets the other, and at the rear.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    VR3 Posts: 29,515
    Yeah I was going to say that formica is pretty thick
    Looks good from north Carolina and it's obviously held up a bit
  • There was the thinner stuff recommended only for vertical surfaces (V32?) but I don't think this looks like that either. Color core came later I believe.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • odcics2
    odcics2 Posts: 382
    The old guy called it "Birdseye", referring to the knots in the "wood".
    VR3 Posts: 29,515
  • odcics2
    odcics2 Posts: 382
    Yup, Birdseye Walnut.
    F1nut Posts: 51,912
    Ugh!
    Definitely worn out formica
    Definitely mortite
    Definitely not birdseye anything
    Possibly supposed to be walnut, but Polk offered walnut vinyl, so why cover them with formica!?!
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • odcics2
    odcics2 Posts: 382
    These formica speakers are a lot lighter than Polk walnut vinyl.
