7A with unique cabinets
odcics2
The original owner had the dealer put formica on them to match his decor at home better.
Those look nice! I was thinking of maybe doing wood veneer on my 7s. Did you just get those? I got a pair a few months ago and changed out the old capacitors. Very inexpensive and makes a huge difference."Equality is a myth to protect the weak. Some of us are strong in the Force, others are not. Only a fool believes otherwise." - Sith Proverb.
Those are poor looking joints and with the sloppy caulking job on the tweeters it gets 2 thumbs down from me.
Thats probably not caulking behind the tweeter. Its probably mortite that they used on the very early ones. I just got a pair of minis and they had it on there just like those."Equality is a myth to protect the weak. Some of us are strong in the Force, others are not. Only a fool believes otherwise." - Sith Proverb.
That’s mortite. These haven’t been messed with.
Perhaps the joints looked better when new?
Anyway, I think they look cool and are certainly unique. I have the original boxes too.
As a plus they are airtight and sound great. -
I agree, sweet looking pair of 7s. Nothing screams 1970s like formica! I think they are awesome!"Equality is a myth to protect the weak. Some of us are strong in the Force, others are not. Only a fool believes otherwise." - Sith Proverb.
I'm sure it made the cabinets stiffer.
I'm also pretty sure they had a wood veneer, walnut maybe 🤔 -
I'm pretty sure that no "dealer" was installing walnut formica on Monitor 7s
Somewhere I have a brochure that showed that, for a time, they were available with real wood walnut veneer.George / NJ
Onkyo A-8017 integrated
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
Gardenstater wrote: »I'm pretty sure that no "dealer" was installing walnut formica on Monitor 7s
Just relaying what the old guy said...
I'd think that the "dealer" would have sent it out to be reworked. The "dealer" certainly didn't do it in his back shop... Or did he?
Maybe the dealer and original owner were buddies? Maybe it was a favor?
I agree that the cabinets would be stiffer. That's always a good thing.
The front edges are the original vinyl. Can't be seen when the grills are on.
FYI - the back has no Formica. -
Formica of the era definitely had a prominent inner substrate of dark brown phenolic, and the melamine finish layer was applied to that. Would be very obvious at the edges where one panel meets the other, and at the rear.George / NJ
iFi nano iDSD DAC
iPurifier3
Yeah I was going to say that formica is pretty thick
Looks good from north Carolina and it's obviously held up a bit- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
There was the thinner stuff recommended only for vertical surfaces (V32?) but I don't think this looks like that either. Color core came later I believe.George / NJ
iFi nano iDSD DAC
iPurifier3
The old guy called it "Birdseye", referring to the knots in the "wood".
Looks like walnut to me
https://www.materialbank.com/specified-solutions-forestree-rustic-knotty-walnut-1949142- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Yup, Birdseye Walnut.
Ugh!
Definitely worn out formica
Definitely mortite
Definitely not birdseye anything
Possibly supposed to be walnut, but Polk offered walnut vinyl, so why cover them with formica!?!Political Correctness'.........defined
President of Club Polk -
George / NJ
iFi nano iDSD DAC
iPurifier3
These formica speakers are a lot lighter than Polk walnut vinyl.
