Amps for SDA 3.1's
xjghost
So I'm researching which amps might pair well with my Yamaha 3030 receiver and my 3.1's. My receiver has pre amp outs. I was using a Hafler 500 but it needs some love. Then I went with my Adcom 555II but my Parasound 800 stopped coming on so the Adcom is on my 10's in my basement office. Parasound has a power switch issue. I live in rural South Carolina and there are zero options for repair on anything. Some day I will have to learn how to fix these things because the closest option is 2 - 3 hours away or ship them. Anywho I digress. I was looking on eBay and FB marketplace at what was out there. One thing I do want is a trigger so when we turn off the tv the amp goes off with the receiver. SO do the Polk nuts have any suggestion on what to look into? Budget is $250 - $500 but really want the best bang for buck deal I can find.
HT/2Channel: Emotiva MMC-1, Adcom GFA-555II, Polk SDA 3.1's, Teac TN-300 TT, Polk Center and Sub.
Bedroom system: Carver CT-24, Parasound HCA-800II, Monitor 10's
Additional projects: RTA 12c's
nooshinjohn wrote: »
Not familiar with Proton at all. I do like the big sweeping VU meters. However it doesn't have the 12v trigger.HT/2Channel: Emotiva MMC-1, Adcom GFA-555II, Polk SDA 3.1's, Teac TN-300 TT, Polk Center and Sub.
Additional projects: RTA 12c's -
Proton was NAD gear on steroids. Good stuff!
Is that all one piece the silver and black chassis if so that's massive- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Time for new glasses my friend
The Proton is sitting on white foam, which is sitting on a Cambridge integrated. -
Didn’t know that was an option. Never seen that.HT/2Channel: Emotiva MMC-1, Adcom GFA-555II, Polk SDA 3.1's, Teac TN-300 TT, Polk Center and Sub.
Always wanted a Carver amp. My plans may have changed. Had a mishap with my Jeep off roading yesterday and my amp budget just shrunk. Thinking I’ll get that trigger though and try it with my Hafler.
Those trees and rocks jump out of nowhere, don't they!?!
Actually was more of a too much go but not quite enough.
I see rocks
Bet it was fun until... -
Yep.HT/2Channel: Emotiva MMC-1, Adcom GFA-555II, Polk SDA 3.1's, Teac TN-300 TT, Polk Center and Sub.
Private park called Gulches here in South Carolina. I’ve made that obstacle multiple times. Yesterday I was hammering hard to get up the slick face and she swung sideways. On the slide down it had enough momentum to flop it over. Usually doesn’t do that but it was slick.HT/2Channel: Emotiva MMC-1, Adcom GFA-555II, Polk SDA 3.1's, Teac TN-300 TT, Polk Center and Sub.
Can't really tell from the photo how your rig fared. Hopefully nothing major, but sure still enough to be a bummer.
Door and a-pillar from that roll?
Do your club guys run beaters?
Guessing you guys trailer out to the park?I disabled signatures. -
That rig faired fine from that one. It’s beat not babied. Yea I trailer it everywhere. Mine is definitely a beater. The guys I were with one had a wide open design buggy the other has a ford ranger with a built 302 and 43” stickies.
A little Duct Tape will fix it right up …
BkPS Audio S300 , WiiM Ultra , Yamaha wxc-50 , Salk SuperCharged Songtowers , Kimber Kable 4TC, Sony 48” - BEDROOM
B&K EX-442 ( it will go in my casket when I die ... ) , PS Audio 4.6 preamp ( old school , but it still jams on ... ) , Eversolo DMP-A6 , Boston Acoustic voyager 7’s - POOL
Parasound A21, Eversolo DMP-A8 , Kimber Kable 4vs , Ascend Acoustics ELX Ribbon Towers , Sony XBR-A8F 65” OLED - DEN , MAIN system
Onkyo TX-nr609 , Polk atrium 7 , Boston acoustic sound ware (4) , Boston acoustic sub , B&W center , Sony 65” TV - PATIO -
Buddy of mine is big into Hafler. Built a 500 kit in early 1980s. Purchased lots more via eBay. I don't know how many he's got now--DH500s, an XL280, and a few DH220s? DH250s? Whatever it was that was the little brother to the DH500s, before the XL series. Some commercial (phone jack input) some "home" with RCA input.Thinking I’ll get that trigger though and try it with my Hafler.
Musical Concepts has update kits and repairs, as did AVA and perhaps others.
This popped up on FB MP.
https://www.facebook.com/marketplace/item/8756160857794114/?ref=search&referral_code=null&referral_story_type=post&tracking=browse_serp:525bcb04-ec9e-49f0-a41a-3c861f963d0e
Onkyo M-282 Two Channel Amplifier
$150
Owned one of those before. Price should be closer to $100. Wouldn't recommend.
Thanks for that info. Pulled the trigger on the Niles switch. Will hook the Hafler back up when it comes in and see how it works.HT/2Channel: Emotiva MMC-1, Adcom GFA-555II, Polk SDA 3.1's, Teac TN-300 TT, Polk Center and Sub.
Ok I'm keeping the dream alive. What about Audiosource? Are they decent?HT/2Channel: Emotiva MMC-1, Adcom GFA-555II, Polk SDA 3.1's, Teac TN-300 TT, Polk Center and Sub.
