Polk S vs R Series for Left and right speakers
Like mentioned in my first post I am about to build my first Polk home theater set. I will follow the recommendation I got to build the system gradually. I will start with a AVR and 2 left and right speakers.
I will get a marantz cinema 60 for 899 Euro (black friday deal) and for the rest budget of 1601 Euro ( the full budget was 2500 euro) I want to get a left and right speaker and in case some money is left a subwoofer or a center channel speaker.
Would you consider the center channel speaker as the more important upgrade or the sub.
But now to the question in the subject line. Would the S or the R Series make a better entry level left and right speaker. The main purpose of the is going to movies and games. No listening to music.
  • boston1450
    boston1450 Posts: 7,758
    For HT your most important speakers are your Center channel & subwoofer.
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • Mrx_085
    boston1450 wrote: »
    Thanks for the info. So just getting the cheapest opion or the front speakers und investing more money into a good center channel and a subwoofer is the way to go?
  • boston1450
    You get what you pay for. Cry once & enjoy
    Randy-Maine
    by David WMG
  • Mrx_085
    boston1450 wrote: »
    That is a great advice. After doing plenty of research I decided to with R Series. I will either get R200 or R300 as left and right speaker. I am now doing some research about center speaker.
    @all which center speaker would serve as good partner for the r200 or r300?
    pitdogg2 Posts: 27,780
    Reserve R400
