Can MagniFi MAX SR connect to MagniFi Min sub woofer?
Nextom
Hello,
Does anyone know if a MagniFi MAX SR sound bar can connect to MagniFi Min sub woofer?
Hello,
They are not compatible, only the MagniFi Max subwoofer will connect to the soundbar. -
Thanks for your reply, how about Magnifi 2 woofer? they look identical? My sub woofer is not working. I'm looking for a solution here.
Not sure, I'll ask.
Only the sub that is part of the system will work. Are you still within the product warranty period?
