Best integrated amplifier for Polk S60
Hi,
I checked all and so far there is no topic for S60 series of speakers.
Currently I'm using Yamaha AX 596 and wondering to what I could update to receive maximum from these speakers. I use them to listen almost all - 60% rock, 30% jezz, 5% electornic, 5% rap.
I saw several threads on this forum but all of them were for amplifiers costs 10k eur so I have doubts that its necessary for such speakers...
Question what could be recommended by You to get maximum from these speakers ?
Secondly what would be economicaly justified for them with big jump in quality from my Yamaha ?
  • PSOVLSK
    PSOVLSK Posts: 5,381
    I’m a big fan of Vincent, though I’ve not run Polks on one. I was also very happy with a Peachtree integrated runnning my LSiM 703. Also had a lower level Cambridge Audio that was fantastic for the price. Many good choices.
  • Emlyn
    Emlyn Posts: 4,708
    You'd probably need to spend $800-$900 to get a new Yamaha integrated amp with similar power output to what you have now but it would have more modern digital features like a built in DAC.
    How much would you want to spend for a big jump? Are you thinking more power, more features, or both?
  • T3kA
    T3kA Posts: 6
    edited November 2024
    As input I build by myself raspberry pi 4 + protoDAC with further plan to extend the build by iancanada parts so other features as integrated DAC are not necessary. I do not need to buy anything new streigth from store as many ppl as audiophiles are positivity crazy and sell in good prices good equipment just to try something else ;).
    1. I would say that 800-1000 EUR is not a problem.
    I could spend such money for something which will be really good and for something which I could also use for my future dream -->R700
    Here I would appreciate few models with short description what to expect which I could search
    2. Something more affordable just for S60's at the moment I don't want to say what I have on mind and just read what You propose
  • T3kA
    T3kA Posts: 6
    No one is willing to share some thoughts in affordable price range ? So I will share my thoughts what I think off:
    -MF m3si
    -Cambridge cx81
    -Yamaha A s801
    Any other recommendation with small characteristics ? What do You use to power the polks S60's ?
    F1nut Posts: 51,770
    MF m3si
    Look no further.
  • T3kA
    T3kA Posts: 6
    And what would You say if in future I would buy Polk R700 ?
    What You would recommend than and what price range I have be ready ?
    Preferences are natural sound not colored and I like bass but polks has planty of it so I think non of amplifiers will hurt it - right ?
    F1nut Posts: 51,770
    I'm not really understanding what you are asking.
    FYI, the sound of every piece of audio gear is colored.
  • T3kA
    T3kA Posts: 6
    Just looking for confirmation if it will be also ok for r700 in future or maybe it's better to add 500eur more and buy something better. In such price ranges I have completely no idea how it sound and if there is a difference which can be hear clearly or it's about 1% improvement. Anyway thank You very much for You time.
    F1nut Posts: 51,770
    No doubt, the MF M5si is the better one, for now and the future, so if it is in your budget you should get that one. It is a big step up.
    Post edited by F1nut on
