New to me Monitor 7 and 5
  • DeRod
    DeRod Posts: 249
    3M 300LSE
    Thank you! I'll give that a shot before trying the stinky glue :D
    "Equality is a myth to protect the weak. Some of us are strong in the Force, others are not. Only a fool believes otherwise." - Sith Proverb.
  • Gardenstater
    Gardenstater Posts: 4,783
    edited November 2024
    Here's a couple of repositionable/temporary ones that might be worth a try and they are from Aleenes:
    https://quiltingthread.com/products/aleenes-tack-it-over-and-over-repositionable-glue-4-ozaleenes-tack-it-over-and-over-repositionable-glue-4-oz
    https://quiltingthread.com/products/aleenes-no-sew-temporary-fabric-glue
    The removable gummy glue hot melt types require a special low temperature hot melt glue gun. I don't know if you could just put a speed control on a regular one and throttle down the temperature, or if the glue sticks are available in a size to fit the regular guns.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • DeRod
    DeRod Posts: 249
    edited December 2024
    Well I got so into into my 7s that I haven’t done anything with my 5s yet. This evening I decided to start looking into the 5s.
    First thing I noticed was the poly in this box was different from all my other Polks. It completely filled the box and was nicely cut out, not rolled up behind the tweeter and MW. It goes all the way to the bottom filling behind the PR.
    Also I noticed the crossover was slightly different with a 6.2 ohm resistor. I thought I had everything needed to refresh that crossover but that 6.2 was a curveball I didn’t expect.
    Just checked and parts has a Jantzen 6.2 .. I guess the crossovers will have to wait till next week when the resistors arrive. Mean while going to start putting in hurricane nuts in preparation
  • DeRod
    DeRod Posts: 249
    The crossovers on these also had metal standoffs not the plastic one they started using later. The inductor isn’t glued or zipped tied.
  • Gardenstater
    It is interesting to me that it "appears" that the tweeter cap is another TSI electrolytic. But if so, it would be odd that it is larger than the 34uF 🤔 Is the tweeter cap 12uF like in later crossovers?
    The 6.2 Ohm tweeter resistor is of course interesting as well. Have you had a chance to check the DCR of those Peerless to see if Polk may have been correcting for ones that had a lower than the usual 7.8 Ohm?
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • DeRod
    DeRod Posts: 249
    Yes 12 & 34uf just like all the others. Just wasn’t expecting the 6.2ohm resister. After digging around the the forum here I did see a couple of other folks had these same crossovers in their older 5s with that 6.2 as well.
    I didn’t notice any of the other model 5 crossovers with the metal standoffs like these though. The crossovers don’t have a date, but the back of the woofers from the same speakers are dated 11-1978.
  • DeRod
    DeRod Posts: 249
    I will check the tweeters tonight and post results.
    I also noticed the other 5s with the same crossover as these had the same pant leg type poly inside. It seems as though that these had twice the amount (2 pant legs) in each speaker from the top to the bottom behind the PR. The boxes are basically stuffed. If you try rolling up the pant legs behind the MW its far too tight. If I remove one from each speaker then I could roll it up like you normally would on all the other Polk speakers.
  • DeRod
    DeRod Posts: 249
    The serial is on the paper tag not a label on the crossover.
  • Another possible explanation for the 6.2 ohm (rather than 4.7 or 4.5) could be that the Gefco Mfg. drivers were less efficient than later ones. "If" they had copper plated pole pieces they could be less efficient.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • DeRod
    DeRod Posts: 249
    Both tweeter 8.2 ohm but notice they have slightly different caps on the magnets.
    The tweeters in the 7s are both the same.
  • DeRod
    DeRod Posts: 249
    Woofer and tweeters from the 5s ☝️
  • VSAT88
    VSAT88 Posts: 1,298
    Not all that unusual from what I have seen from buying multiple Polk vintage speakers. Some were that way from the factory. Using up older parts in newer production speakers. Hey! Look! we have another box of mid woofers sitting over here in the very back of the storage room! Some times owners change them out if they blow them and have no clue except if it fits then there you go. No care as to model number, specs, whatever. Then you have the cruel ones that know its the wrong speaker and put em in anyway just to sell the. Whats the old saying??? Buyer Beware!
  • Gardenstater
    Comparing schematics for 5B vs 7C, both having the same MW6502 + SL2000 drivers, the schematics are the same except for the 5B not warranting the mylar tweeter capacitor and getting an electrolytic. So the question would be why are the schematics for 5A vs 7B different when they both have the same MW6500 + Peerless? I'm assuming the only difference is the tweeter resistors (6.2 Ohms vs 4.5 Ohms) but what if there are inductor differences, especially in DCR?
    Maybe you could check the DCR of the MW inductor.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • DeRod
    DeRod Posts: 249
    Question - would a Jantzen 18uf + 16uf to equal 34uf be good idea or just a single 33uf ?
    pitdogg2 Posts: 27,066
    Either would work.
  • DeRod
    DeRod Posts: 249
    Either would work.
    Once again thanks for your advise. I didn’t want to make the same mistake as with the 7s when you pointed out making a more even split would be better.
    I’m going to give the Jantzen 18+16 a shot and use an Audyn 12uf with Jantzen resistors for the Monitor 5. The only thing I’m missing is the 6.2 resistor which is already on the way to me. I’ll probably start on these tonight
  • DeRod
    DeRod Posts: 249
    Still waiting on the resistors to arrive. Did some Dynamat and hurricane nuts meanwhile.
  • DeRod
    DeRod Posts: 249
    edited February 2025
    I got the 5s crossovers recapped finally. I will work on the 7Bs next.
    I used Jantzen crosscaps 18uf + 16uf and a Jantzen Z-cap for the 12uf. Mills resistors.
    I’ll let you know how they sound after I give them a good listening to.
