Remote control of Magnifi Mini doesn't work
Fernando22
Hello good day, my remote control for my Magnifi Mini stopped working overnight, at first I thought it was because of the batteries, but I changed them and still did not work. I tried to try with the camera on my phone to see if it sent a signal with the led inside but it did not light up, so I opened the control and I came to ask if there is any way I can fix this problem?
Answers
Most of the time the problem is with the infrared LED. The first thing to do is place a DC meter across the two LED terminals, install the battery then push a button and see if there's voltage across the LED.
Have you tried contacting Polk to see if they have them, is it still in warranty? -
SeleniumFalcon wrote: »Most of the time the problem is with the infrared LED. The first thing to do is place a DC meter across the two LED terminals, install the battery then push a button and see if there's voltage across the LED.
Mmm I want to believe that no, when I bought the sound bar in September of this year a week later it stopped playing when I wanted to connect it to Chromecast, I asked in the forum what I could do since I am in Mexico, they gave me some contacts and I sent my bar to them, but the replacement they gave me does not work with HDMI and now the control died, I guess there is nothing more I can do 🤷🏻♂️ -
Do you want to try fixing the remote yourself? Have you contacted the people who sent you the replacement and explained that you are having trouble with the HDMI connection and the remote has stopped working?
SeleniumFalcon wrote: »Do you want to try fixing the remote yourself? Have you contacted the people who sent you the replacement and explained that you are having trouble with the HDMI connection and the remote has stopped working?
Yes, to save time and yes I also told the people who sent me the replacement about the HDMI, they told me to corroborate that it was not the cable, it is not the cable, then they told me to wait a moment and from there I have not been told anything else. -
The first thing to do is to determine if the problem is with the LED or with the circuitry that drives the LED. Do you have a volt/ohm meter that can measure DC volts?
SeleniumFalcon wrote: »The first thing to do is to determine if the problem is with the LED or with the circuitry that drives the LED. Do you have a volt/ohm meter that can measure DC volts?
Yes i have it! -
What you are going to do is set the meter to read DC volts and put the battery in the remote. Then with the meter's probes on each of the two leads that are connected to the LED push any of the remote's buttons and see if there is any voltage going to the LED. It will probably be 1 or 2 volts.
Was this your contact person:
ana.graziano@soundunited.com -
SeleniumFalcon wrote: »Was this your contact person:
My contact person was hifi.service@gruporecse.com i think u gave me this email and this number +52 5559895989.
When im in home i will try what you told me to do with the DC Meter, thx -
You might want to contact the second person and explain what happened and she could send you a new remote.
SeleniumFalcon wrote: »You might want to contact the second person and explain what happened and she could send you a new remote.
She was the fisrt person i send an email since August 27th but she didn't answer me, i'll try again.
With the DC meter i got 0 on the results -
That probably indicates that the problem is with the circuitry that drives the LED rather than the LED itself. I'll mention to my friend that you didn't receive a response from her.
I believe a new upgraded soundbar is headed your way.
SeleniumFalcon wrote: »I believe a new upgraded soundbar is headed your way.
Yes! just saw the email, I really appreciate your support, you are the best -
I hope this gets things straightened out for you.
Tenacious!"Sometimes you have to look to the past to understand where you are going in the future"Harry / Marietta GA
