how to wire
Systems
Systems Posts: 14,872
edited March 2005 in Car Subwoofer Talk
have 2 mm2104 in a ported box how do i wire them. together or seperate and why thanks
Testing
Testing
Testing
  • MacLeod
    MacLeod Posts: 14,358
    edited March 2005
    It depends on what amp youre going to be using.
    If youre running a Class D amp you would wire each subs + to the amps +. Then run each subs - to the amps -. This would present a 2 ohm mono load.
    If youre running a pair of 2 channel amps then you would run one subs + to one amps left + then that subs - to the amps right - and that would be a 4 ohm mono load. Some amps may vary and it may be the left - and right +. Either way it will be plainly marked on the amp.
  • neomagus00
    neomagus00 Posts: 3,899
    edited March 2005
    beyond what mac said, there's no way for us to tell unless we know what amp you're using.
  • Systems
    edited March 2005
    could you tell me which way would sound the best. dont have amp yet wanted to see if i needed a 2 channel or a single channel please recomend
    Testing
    Testing
    Testing
  • MacLeod
    edited March 2005
    They have no effect on sound. It all depends on the amp and wiring them up properly for that particular amp. If you hook up both subs in a 2 ohm mono load to a 4 ohm mono amp, youre going to fry your amp.
  • exalted512
    exalted512 Posts: 10,734
    edited March 2005
    some ppl can tell the difference b/t an AB and D amp...
    -Cody
  • neomagus00
    edited March 2005
    on a 2104 with decent amps? i find that unlikely. maybe on a brahma or an eclipse aluminium or the like, but not on that. imo.
  • MacLeod
    edited March 2005
    I dont think you could. 500 watts is 500 watts. Regardless if its coming from a Class D, T, A or A/B.
    I guess you could in frequency response as most Class D sub amps dont go beyond 200 Hz.
  • Systems
    edited March 2005
    which class d amp would you recommend?
    Testing
    Testing
    Testing
