how to wire
Systems
have 2 mm2104 in a ported box how do i wire them. together or seperate and why thanks
Testing
Testing
Testing
Testing
Testing
It depends on what amp youre going to be using.
If youre running a Class D amp you would wire each subs + to the amps +. Then run each subs - to the amps -. This would present a 2 ohm mono load.
If youre running a pair of 2 channel amps then you would run one subs + to one amps left + then that subs - to the amps right - and that would be a 4 ohm mono load. Some amps may vary and it may be the left - and right +. Either way it will be plainly marked on the amp.polkaudio sound quality competitor since 2005
beyond what mac said, there's no way for us to tell unless we know what amp you're using.It's not good, very fundamentally simply not good. - geolemon
could you tell me which way would sound the best. dont have amp yet wanted to see if i needed a 2 channel or a single channel please recomendTesting
Testing
Testing -
They have no effect on sound. It all depends on the amp and wiring them up properly for that particular amp. If you hook up both subs in a 2 ohm mono load to a 4 ohm mono amp, youre going to fry your amp.polkaudio sound quality competitor since 2005
some ppl can tell the difference b/t an AB and D amp...
on a 2104 with decent amps? i find that unlikely. maybe on a brahma or an eclipse aluminium or the like, but not on that. imo.It's not good, very fundamentally simply not good. - geolemon
I dont think you could. 500 watts is 500 watts. Regardless if its coming from a Class D, T, A or A/B.
I guess you could in frequency response as most Class D sub amps dont go beyond 200 Hz.polkaudio sound quality competitor since 2005
