Has anyone compared the hts12 vs es12 subwoofer?
I need to buy the most powerful subwoofer from Polk. Hts 12 has good reviews but I would like something a little stronger and signature es12 is the perfect size for my living room. Which one will be louder and more powerful?
    pitdogg2 Posts: 27,372
    Polk Subwoofer, surely you're joking.
  • Hello,
    Welcome to the Polk forum. I've asked a product specialist, at Polk, to explain the differences in the two product series. Good post, by the way.
  • His response:
    "The ES series is a completely different design and is the better by far of the two series.
    The new amp has almost no latency when compared to previous models and is the best sub amp we have ever made.
    They are using higher temperature woofer voice coil wire in the new woofer along with dual ports.
    The advantage of dual ports is that lowers the vent air velocity and is much quieter at higher volume levels.."
  • TomekOstroleka
    TomekOstroleka Posts: 3
    edited October 2024
    I'm waiting for the first tests. I wonder how it will compare to SVS or Klipsch. does it really have 300w rms? the price is tempting
  • mrloren
    mrloren Posts: 2,474
    WOW for the MSRP look at HSU
  • Is there anyone who has already tested this sub? I'm interested in how it plays compared to the SVS Pb 1000 pro. Is it worth paying extra for SVS?
    Yes, SVS, HSU, Rythmik all much better subs.
  • Polk Subwoofer, surely you're joking.
    You better show Polk audio how to design their subwoofers. ๐Ÿ™„ ๐Ÿ˜‚
    SUPERMAN
    You and I have been here long enough to remember when they did have good subwoofers. Subwoofers and soundbars, those two get the most complaints in the last decade.
    VR3 Posts: 29,555
    One post per decade has to be a record
  • VR3 wrote: ยป
    Or I can talk **** about things I don't care to know. I have better things to do then talk how Polk doesn't know what they are doing. They seem pretty successful to me :)
    SUPERMAN
    Yea, I never considered their soundbar or anyone else's for that matter. I do understand what your saying too but I just don't care about it enough anymore. I just keep myself busy doing what I do and listen to the music. Happy just to listen
    SUPERMAN
    msg Posts: 10,479
    Most of what I've seen complaints with have been the entry level PSW subs. I'm loosely interested to hear this newer Polk Signature Elite ES12, though, since it's been a while since I've heard a Polk sub.
    That said, I just did a bit of quick reading.
    The Polk Signature Elite ES12 doesn't offer room correction or a remote. For that money, approx $850 for the 12" model, I'm sorry to say, I'd have to be comparing other options myself, even if it meant buying something used that does have room correction and a remote.
    I will say though that that perspective is for a music-first sub, which also makes a difference in selection for a few reasons.
    For music, once you experience tight control and bass texture, it's hard to go back to one-noter subs, or flabby room shakers. Still though, when budget dictates, and it's usually a factor for most of us, the best you can reasonably afford is better than nothing.
    Additionally, the room correction and remote are fantastic options to refine your sub for use with an integrated or preamp that doesn't offer room correction or bass management. This has become a huge selection factor for me in my most serious system.
    Remote and room correction are "nice to haves", and make a difference for on the fly adjustments when listening to genres with changing bass presence. That said, I've had pleasing experiences with MartinLogan Abyss, Grotto, and Depth subs for music, none of which have room correction nor remotes. Once set up, I've found them mostly good to go with the exception of sub volume between genres.
    For HT use with an AVR that offers room correction, remotes and room correction mic capability are less a factor. Then you can look more for depth and speed.
    Other factors are controls for the tightness of the bass. HSU subs, for example, offer a Q adjustment to control the bass decay.
  • i was fortunate to find a showroom where they had an old demo hts12, and the new es12 local to me and hands down the es12 is better. only drawback is it is only available in black. the hts was available in walnut,black, and white to match the other s, and es speakers. the es12 is built like a tank, has plenty of power for my 12x14 room, sounds amazing for hts use, and very very good for 2.1 channel music use. I have been a diehard car audio guy for decades, for a single 12 with advertised 300 watts rms it is impressive to say the least. I was worried I would need a pair due to my mains being es20, but it is more than adequite. have not taken any rew measurements yet, but it easily covers 20-100 hz, not boomy, very tight and musical. only complaint is the price. For my first venture back into home audio systems in 20 years the es35 center, es20 mains, es15 rears, and es12 sub is a better than average system. was not expecting much for the pricetag and it has easily surpassed all of my expectations.
