Lets hear your DAC recommendations
Alright, I'm looking for a DAC. Not interested in one that makes peanut butter sandwiches, just looking for a unit that has a decent chip in it.
So far, I've found the Shiit Modius and the S.M.S.L SU-9 PRO. These two should integrate well with my set up: Marantz 8802A and Emo ERC-3 CDP. And are in my price range. I'd like to not go over $500
I'd like to hear from y'all if anyone has any other recommendations they want to share, thanks in advance.
Set up: 11.2 HT + 2ch
  • SIHAB
    SIHAB Posts: 5,551
    edited September 2024
    Hi,
    your setup is pretty nice. You just want to play around with a DAC?
    Of the two, the SMSL looks really cool. B)
    VR3 Posts: 29,520
    I've found some abbas dacs used pop up at that price.. It's the way to go
    billbillw Posts: 7,730
    If you are patient, you might be able to find used Denafrips Aries II in that price range. I grabbed mine without too much patience last winter for just barely over your upper price point.
    Otherwise, I'd recommend something like a Topping D70S or one of the D90 with AKM chips. I personally don't like the SABRE sound, but many do.
    VR3 wrote: »
    That looks to be a real patience tester...
  • Geoff4rfc
    Geoff4rfc Posts: 2,926
    SIHAB wrote: »
    Hi,
    What else would you be thinking?
    nooshinjohn Posts: 25,973
    If your plan is to connect the new DAC to the Marantz, I do not believe we will see any improvement in performance. The Marantz is a good AVR, and has a DAC built in I believe,but it is not a two channel channel preamp. Whatever signal is being fed to the new DAC will mostly sound exactly like the one already inside the AVR, especially at the lower price point you are looking to be at.
    If I was in your place, I would begin by looking for preamp with HT bypass and build from there.
    VR3 Posts: 29,520
    Eh, I've seen several pop up but they sell extremely fast
    Set an alert on hifi shark
  • stangman67
    stangman67 Posts: 2,328
    I’ve got a Northstar Intenso that has dim/almost dead screen and cuts out from time to time (goes away with a power cycle). Yours if you want it to play around with. Sounds pretty damn good IMO
  • rooftop59
    rooftop59 Posts: 8,120
    I do agree with this, but some dacs can also function as digital preamps. I would look for one of those and feed the source directly to it...
    Game Room 5.1.4:
    Bedroom 2.1
    rooftop59 wrote: »
    I have yet to see a DAC/digital preamp also offer HT bypass, which will likely be needed in his case. I had a Simaudio 380d DSD Feeding into my Arcam AVR20, and there was an improvement, but it was only after the McIntosh C2300 was introduced that the full potential of my rig was unleashed. The Preamp made significant improvements whereas the DAC only modestly so.
  • SIHAB
    SIHAB Posts: 5,551
    Geoff4rfc wrote: »
    SIHAB wrote: »
    Hi,
    I think the above suggestions of Tube DAC or Denafrips are good ones.
    You are talking flavors I think now.
    What are you trying to improve?
    Detail? Timbre? Smooth out the "digital sound"? Warm things up a bit?
    People swear by the Chord MOJO but I have no experience with
    https://www.ebay.com/itm/156329675439?_skw=cord+mojo+DAC&epid=9062154498&itmmeta=01J7S7AN6DRYJJTHTYCK5DGWHM&hash=item2465f98aaf:g:NUQAAOSwE~RmqRxI&itmprp=enc:AQAJAAAA0HoV3kP08IDx+KZ9MfhVJKmUERNePkSh5MJH/s4ab0YfIlwS83VV4g8WISTwIpEz+lbf5W0cV86+6IB1QeeKqvw+E68HMDwX3f2IEmGaGmzs4hqMkD1QG5brpWOW+XjmW9GVozLsL51Si0DtiVHELDixcWIeDB13SccxWFG5GIQbb5E8WfATNOqucuudXOhu18ptlLpgCqrvLFdIoV8QMYDY3XaTOYAsmGVMJvcRl+tmjcY6qgFreduvnhxxUMhDGVr14oTSJ1l27H/hZvit5XE=|tkp:Bk9SR6TTqqe-ZA
    As an aside, I had this in the cart a couple of days ago but didn't pull the trigger...
    https://tmraudio.com/components/d-a-converters/berkeley-audio-design-alpha-dac-v1-d-a-converter/
    I can hear the Mrs. now :#
  • Geoff4rfc
    Yes, that was my plan, to use the balanced "out" from the DAC to the balanced "audio in" on the processor.
  • Geoff4rfc
    rooftop59 wrote: »
    Emo has the XDA-3 which is a DAC/pre-amp. In this case, go CD to DAC/pre then straight to the amp, by passing the processor all together?
  • Geoff4rfc
    SIHAB wrote: »
    I'm looking to get more detail out of my CD player
    Geoff4rfc wrote: »
    SIHAB wrote: »
    You won’t find it on the path you seek to travel. The biggest bottleneck is using the AVR.
  • GlennDog
    GlennDog Posts: 3,157
    stangman67 wrote: »
    Most folks have no clue just how good North Star Design (NSD) products are… You should get on this offer as fast as you can. Intenzo is the gateway drug to Supremo.
    I’ve got 2 Supremos and the only thing that surpassed that was Lampizaror … Just saying
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
  • SIHAB
    SIHAB Posts: 5,551
    I fear NSJohn is correct. Still, I like a challenge. :)
  • maxward
    maxward Posts: 1,710
    Take @stangman67 ’s offer! I sold it to him and it sounds nice. What bothered me was the display couldn’t be dimmed. Apparently that’s not a problem now.
  • Geoff4rfc
    Geoff4rfc wrote: »
    SIHAB wrote: »
    I appreciate you chiming in. May I borrow your Mcintosh?? :D J/K
    I have pure direct mode on the Marantz, which if I'm not mistaken, by-passes the AVP.
    Geoff4rfc wrote: »
    Geoff4rfc wrote: »
    SIHAB wrote: »
    I have the same, moron, my Arcam but it still is no substitute for a separate preamp. Please don’t get me wrong, what you are trying to do can sound good, but you are missing out on far more than you realize until you try it
  • Geoff4rfc
    Geoff4rfc wrote: »
    Geoff4rfc wrote: »
    SIHAB wrote: »
    I can dig it......."moron????" c'mon honey, it's not polite to call people names
  • stangman67
    Geoff4rfc wrote: »
    Geoff4rfc wrote: »
    SIHAB wrote: »
    Wow strong words. To be fair when you got that Arcam you raved how it sounded better than all the separates equipment it replaced….. we all knew you were wrong but looks like we have finally come full circle.
    There are many others that have earned the title Moron (to include myself and you), but I can’t see how this Geoff earned that in this thread.
    Geoff4rfc wrote: »
    Geoff4rfc wrote: »
    Geoff4rfc wrote: »
    SIHAB wrote: »
    Omg!!!! So sorry!!! I was using voice recognition while posting from a birthday party at a sports bar and that word must have gotten picked up by my phone. I did not say that and it should have NEVER been posted!!!! Very, very sorry!😳😳😳
    After looking further into the original question and realizing it is proposed to mate it with an AVR, I would also suggest that won't get you much improvement.
    A high level DAC will never reveal all its capabilities until it is mated to a decently high end 2-channel analog preamp. Even in pure direct mode, there is too much happening to the signal inside that complex, multi-board AVR.
    I'd hold off on a DAC.
  • Geoff4rfc
    Geoff4rfc wrote: »
    Geoff4rfc wrote: »
    Geoff4rfc wrote: »
    SIHAB wrote: »
    Lol, no worries. You can make it up to me by buying me a beer at the next party. B)
  • On the very rare time that I'll spin a cd I find that the dac in my Cambridge Audio 851n to be an excellent match up with my Emo erc3. Much much better than my dated Mcintosh d100 dac which it replaced.
  • SIHAB
    SIHAB Posts: 5,551
    Going in a different direction, I've been eyeballing this little streamer for studio 2.
    https://www.cambridgeaudio.com/usa/en/products/hi-fi/mx/mxn10
    Ive heard good things about it. And it fits the budget.
  • SIHAB
    SIHAB Posts: 5,551
    Believe it or else, this would probably dig out more detail for you.
    https://tmraudio.com/components/d-a-converters/emotiva-xda-2-dac-d-a-converter/
    Pull quote from Darko;
    "Some buyers will probably pair it with Emotiva’s own power amplifiers (which I’ve not heard). System matching is more critical with this DAC. Personally, I’d add a more buttery tube amplifier to an XDA-2 fronted system; tonal thickness and a little treble taming (more so than other DACs deployed in this review) would go a long way to ensuring you could have your detail cake AND eat it." - Darko Audio
    I had this DAC and completely agree.
  • Geoff4rfc
    SIHAB wrote: »
    It would be nice if Emo still carried the xda 2, they now have the xda 3 which I've been pondering but man...trying to justify the cost to benefit ratio....aside from my AVP, my components are made up of Emo's, erc3 cd player, xpa-dr3 amp are what make up the 2ch section of my set up.
  • Emlyn
    Emlyn Posts: 4,800
    My answer would also be none of the above under $500. Have you tried to play a CD from your Blu Ray player over both HDMI and over the balanced analog outputs into the 8802 using the direct modes in both the player and and 8802? If you can't notice a difference in Pure Direct mode compared to the Emotiva CD player that's a good indicator. If you can then it may be worth investing in a DAC above the price threshold you're looking at. The internal DAC in the 8802 is also high performance, including for high resolution PCM and DSD, and may be at least as good as that in external devices under $1K although the rest of the 8802 does have its own analog sound character that can't be eliminated.
    My take is an inexpensive DAC is likely to be powered by a switching power supply that'll end up inserting line noise and sibilance. There are numerous ones under $100 to test that out.
    The Emotiva DAC is probably where you should be looking for an upgrade. You could try it and return it if it doesn't work out. Having the headphone section and eARC features is a positive.
