polk mm124 2 12" box
Systems
Does anybody know what kind of box to use with the mm124's? as in sealed or ported. Thanks.
Testing
Testing
Testing
Testing
Testing
Polk subs seem to work best in a sealed box. Here are the plans.polkaudio sound quality competitor since 2005
It is true that mm2124's are designed for sealed box's but honestly if you want it in any other kind of box have at it. I had one mm2124 in a giant ported box and it kicked ****. but then again i am switching to a sealed only because its a custom thing i'm doing with two mm's and a plexi glass window.
-AustinFrontier -
so would this box be alright for the mm124's?
http://www.bassworx.com/BassCatlgUSint.pdf
page 5 cube series SC212B
thanks -
that will work, but a sealed box is actually rather easy to build (if you have basic woodworking tools and abilities). the box you mentioned is about .24 ft^3 too big. if you get it and find that the bass is too boomy, gluing strips of 2x4 in will fix that.It's not good, very fundamentally simply not good. - geolemon
