polk mm124 2 12" box
Systems
Systems Posts: 14,872
edited April 2005 in Car Subwoofer Talk
Does anybody know what kind of box to use with the mm124's? as in sealed or ported. Thanks.
Testing
Testing
Testing
  • MacLeod
    MacLeod Posts: 14,358
    edited March 2005
    Polk subs seem to work best in a sealed box. Here are the plans.
  • Frontier
    Frontier Posts: 4
    edited March 2005
    It is true that mm2124's are designed for sealed box's but honestly if you want it in any other kind of box have at it. I had one mm2124 in a giant ported box and it kicked ****. but then again i am switching to a sealed only because its a custom thing i'm doing with two mm's and a plexi glass window.
    -Austin
    Frontier
  • Gnomez
    Gnomez Posts: 15
    edited April 2005
    so would this box be alright for the mm124's?
    http://www.bassworx.com/BassCatlgUSint.pdf
    page 5 cube series SC212B
    thanks
  • neomagus00
    neomagus00 Posts: 3,899
    edited April 2005
    that will work, but a sealed box is actually rather easy to build (if you have basic woodworking tools and abilities). the box you mentioned is about .24 ft^3 too big. if you get it and find that the bass is too boomy, gluing strips of 2x4 in will fix that.
