Widespread faucet fix
  • Emlyn
    Emlyn Posts: 4,919
    edited March 2023
    That's exactly what I was thinking regarding old school quality and replacement parts. There seem to be standard faucet models that house flippers in my area like to use that look really good in the short term and still get the job done for a few years.
    Viking64 Posts: 7,827
    I wouldn't DREAM of cooperating with plumbers or foundation repairers.
    Also, saying that you are "satisfied with pipe placement" is wrong and it is against the rules.
    xschop Posts: 5,897
    I've used Shark-Bite fitting on 1/2" copper to PEX repair at an older home I had. Lasted 8 years till I sold it.
    VR3 Posts: 29,756
    edited September 2024
    Just remember that shark bites fittings do not maintain grounding bonds... Granted you used pex which doesn't either but you should strap copper piping with a grounding wire if adament on using those fittings
    xschop Posts: 5,897
    Is that why the copper/brass crimp rings on PEX corrode and go bad quickly?
    I'll be using all white PEX with expansion fittings on our new home.
    A few folks I know, myself included have had the blue and red UPONOR brand PEX spring leaks.
    I read the post manfr. process to apply the colored dye causes it to leave the factory with defects/brittle.
    VR3 Posts: 29,756
    In my experience it depends on your water.
    At my house, I installed pex maybe ten years ago and have no issues I've seen.
    I've seen some houses where they are falling apart because of highly corrosive water, usually well water.
    Copper piping is not a whole lot better, you see alot of copper with the red and green dots, it takes longer but it is the same issue truly.
    That is why you see the typical life span of copper is considered 75 years.
    Side note, grounding bond doesn't go to pex since the chance of the piping becoming electrified is non existent and grounding the fittings to reduce c corrosion would be impossible.
    You could also use plastic fittings to help with corrosion
    Clipdat Posts: 13,105
    I wash myself with a rag on a stick.
  • rooftop59
    rooftop59 Posts: 8,120
    Clipdat wrote: »
    I'm sure your wife loves that. Is that your foreplay?
    Game Room 5.1.4:
    Bedroom 2.1
    Woah simmer down there Jimmy Turbo, this is a family forum.
    billbillw Posts: 8,346
    All this because of a spam poster...
  • rooftop59
    Clipdat wrote: »
    I'll take that as a yes...
    Game Room 5.1.4:
    Bedroom 2.1
    treitz3 Posts: 20,366
    Not quite sure I want a ground to copper, during a lightning storm and while I am taking a shower....
    VR3 Posts: 29,756
    all copper piping is grounded or is supposed to be
    Path of least resistance bro'. Gambling is not my thang...
    VR3 Posts: 29,756
    I hear ya.. but... it is. So no showers with copper piping! :)
    txcoastal1 Posts: 13,520
    treitz3 wrote: »
    A jolt make you hung like horse, strong like bull, make wife very happy
    .....she collect on life insurance :D:D
    If pole down, I am dead? Wife not happy. Wait....what?
  • jdjohn
    jdjohn Posts: 3,448
    VR3 wrote: »
    And no showers during thunder/lightning storms! Do we really need to state this?
    Frankly, you should be busy unplugging precious audio gear during a severe storm.
  • jdjohn
    jdjohn Posts: 3,448
    It only takes one.
    VR3 Posts: 29,756
    We live in a society where a plastic bag says don't put on your head or in a crib with infants.
    This should tell you everything you need to know
