My Signa S2 sound bar power not on, I Check the power cord and its found ok but sound bar not power
My Signa S2 sound bar power not on, I Check the power cord and its found ok but sound bar not power on. Also for your kind information this problem before happened but its fixed automatically. But now its not fixed. Please help me.
Answers
    Clipdat Posts: 13,104
    I believe Polk Audio customer service can assist with this, please give them a call at 1-800-377-7655 between 9AM and 5:30PM ET M-F.
  • SeleniumFalcon
    Hello,
    Welcome to Polk's forum. If you are sure your wall outlet is functioning correctly and you've got the power cord firmly attached then there's a problem. You might want to try connecting it to another wall outlet just to be sure. If that doesn't work then contact Polk's customer service at 1-800-377-7655 and have the unit's serial number handy.
  • JahirMasud
    AM6220111851343
