2.7 ohm vishay mills resistor is not available - what is a good alternative?
drop1
Hi all, I'm working on upgrading the crossover on my SDA 2Bs. I have everything ready to order. I'm going with sonicap caps per recommendations on this forum. It looks like most have used a 2.7 ohm resistor from vishay mills however it doesn't look like they have a 2.7 ohm 12w resistor available anymore. And I can't find any alternative recommendations. Can anyone give me some guidance on a decent replacement?
How about this one?
https://partsconnexion.com/mills-resistor-2r7-2-7r-ohm-12w-mra-12-series-1-tolerance/
Or can I use the 5w resistor?
https://www.soniccraft.com/product_info.php/27-ohm-vishay-mills-mra-p-5217 -
The 5 watt is perfectly fine. So is the 12 watt.
Thank you -
Welcome
