Polk Audio RTiA9 Crossover modification
13»
    VR3 Posts: 29,731
    I still do mods for certain projects
  • gp4jesus
    gp4jesus Posts: 2,019
    gp4jesus wrote: »
    VR3 wrote: »
    Thank you!
    Acetal/delrin
    I figured non-conductive. Looks like aluminum and about as strong?
    where to buy that material?
    Looking to make binding post plates
    *all connected w/Premiere ICs
    VR3 Posts: 29,731
  • gp4jesus
    citation16 wrote: »
    So did you hear a difference with the dynamat on the speaker ?
    Yves
    I hope I caught you in time.
    I used Armacell. Did you obtain the material and apply any damping to your driver frames and magnet shields?
    Tap the shields lightly - they easily ring like bells thus all the drivers’ shields NEED Armacell or equivalent. The frames reflect mid and lower treble frequencies. The closure stuffing does NOT absorb or prevent reflection of those frequencies.
    HD & Lowe’s sells Armacell/pipe wrap*, and it’s cheap! Get some if you haven’t before you close up your speaker(s). If you have the patience apply some* on the frame behind the rear of driver cone - I’ve heard the diff.
    Apply either the Armacell*, Dynamat, or Secondskin to the larger portions between the rib bracing of your closure interior. These** may perform better than this* as they’re thicker, but they cost more. Regardless ANYTHING is better than nothing.
    You’ll thank me later…
    Tony
  • gp4jesus
    VR3 Posts: 29,731
    Yes I laser cut them
  • gp4jesus
    Just making’ binding post plates.
    Can I use a miter or table saw w/a blade that cuts wood?
    Or very fine teeth for metal going very slow?
    Thnx.
    VR3 Posts: 29,731
    edited October 2021
    Acetal machines well but carbide bits will eventually overheat faster than in wood
    Table saw cuts well
  • Ryande
    Ryande Posts: 1
    does anyone know the size of air core inductors used in upgraded crossover of RTiA9? in MH please
  • proparts
    Hi there
    How much are those vr3 crossovers upgrade for the rtia9
    F1nut Posts: 52,381
    edited August 2024
    The quick answer, $$$$$.
    You should reach out directly to VR3 for a quote.
